RPM 2.65 trans using B4 slipper.
- askbob
- Been thanked: 4 times
Re: RPM 2.65 trans using B4 slipper.
Here is where I saw the info about the black gear shafts. http://www.rc10talk.com/viewtopic.php?f=36&t=22331&hilit=b4+topshaft+RPM
Thats my original post, not much use thou i'm afraid. it does say black gear shafts wont work. but i know for a fact i snapped my silver gear shaft on my first attempt.
Dont know how to help really
- LowClassCC
- Has thanked: 108 times
- Been thanked: 171 times
beat me to that link.Caine wrote:http://www.rc10talk.com/viewtopic.php?f=36&t=22331
- askbob
Well heck! Anyone have an early B4 shaft with the silver gear?
Reg, you mentioned a brass sleeve. Can you elaborate on that?
you can probably use .001" brass or steel shim stock, like from mcmaster-carr, listed as 'feeler gauge stock', and with some finesse, press it all together. it's dirt cheap other than shipping, I'd say maybe even hit up an auto parts store or something like fastenal and see if they have some. You'd have to take some measurements, maybe half a mil is what you need, .0005"
- klavy69
- Moderator
- Has thanked: 639 times
- Been thanked: 294 times
Not that I know what I am talkin about but have I read that the MIP b4 topshaft is bigger than the associated stock topshaft?
- askbob
You talking about the aluminum shaft from MIP? Been looking at that one too.
- klavy69
- Moderator
Just remember a conversation about this same thing awhile back and can't find it. Might've been me(?) that was told not to get the MIP B4topshaft because it was bigger. If I can find the thread I think it had part numbers in it. Thats about all I can remember from it though...
- Has thanked: 36 times
- Been thanked: 1318 times
the mip topshaft incorporates the b4 topshaft spacer into the design. because of that, you can't use it when doing the b4 topshaft swap on the 2.25 stealth because the spacer is not used.
as far as i know anyway.....
- klavy69
- Moderator
aahhh...thats pretty much the reply I had back a long time ago IIRC
thanx scr8p. I knew there was something about it but couldn't find the thread. Sorry for derailing this...won't happen again well not in this thread again anyway
- askbob
Thanks for that info. Looking at a pic of the MIP shaft you can definitely see the larger portion of the shaft. Well hell!
I'm not sure you could fit any type of shim material at all in there. Plan B...
- Has thanked: 5 times
- Been thanked: 29 times
Im sure i have a top gear/shaft with a bad gear,I replaced a few in my x6 when i had the 3 gear trans with the open bottom.askbob wrote:Well heck! Anyone have an early B4 shaft with the silver gear?![]()
- askbob
That would be great noony! Let me know if you can come up with one.
- askbob
Kinda thought about using a sharp flat punch to dimple the splined area of the shaft for a press fit.
- askbob
After aquiring an early B4 topshaft with the silver gear(thanks!), I can say that there is a difference between it and the newer black gear shafts. The smaller 2.65 RPM gear fit perfect onto the older style shaft.
New shaft on left, older shaft that had the original silver gear on the right. The splines are much more pronounced on the older shaft.
Perfect fit onto older shaft.
- 1783 Views
- 1168 Views
Last post by slow_jun
- 4248 Views
Last post by sneako43
- 1033 Views
Last post by sschering
- 530 Views
Last post by RC10superfan
- 754 Views
Last post by rc10johnny
- 1392 Views
- 1502 Views
Last post by burnsmonkey
