1. Remove the head from the engine.
2. Rotate the crank till the piston is at top dead center (piston can be broken if you don't)
3. Remove the back plate
4. remove the piston sleeve. (these tend to stick but be careful how remove it it's easily damaged)
5. now the rod will slide off the crank pin and the piston rod assembly can be removed.
Always rotate the to TDC alot of back plates have a groove cut in them that the piston skirt will drop into at BDC. If you try to remove the back plate when the piston is in that groove you will break the piston if you force it. As for reassembly after run oil is the best thing to use.
Nitro engine maintenance & disassembly
Re: Nitro engine maintenance & disassembly
Horse power is how fast you hit the wall. Torque is how far the wall moves when you hit it.
- Dr. Robotnik
I will take a pic when I can but basically all you'll be seeing is an engine with no head or piston sleeve with its back plate stuck on. Thanks for all the info. but I think I just need to work on getting the back plate off using the tips previously suggested.Tripp wrote:1. Remove the head from the engine.
Thanks all.
- klavy69
- Moderator
- Has thanked: 639 times
- Been thanked: 294 times
Hey Doc,
My curiosity has been sparked...what motor are you trying to disassemble?
- 964 Views
Last post by marty slater
- 25 Replies
- 2343 Views
Last post by morrisey0
- 1907 Views
Last post by Bakauata
- 3055 Views
Last post by DaveM
- 3090 Views
Last post by doldsen83
- 1155 Views
Last post by USA-1
- 25 Replies
- 5350 Views
Last post by limestang
- 1764 Views
Last post by HS-YZ250
Bing [Bot],
XLR8 and 4 guests
