I need advice on buying a new engine for a Schumacher Nitro 10
Hi, I was recently given a Schumacher nitro 10, and want to put a new engine in it, can anyone suggest one that is not too expensive? Would love some advice.
Re: I need advice on buying a new engine for a Schumacher Nitro 10
Welcome too the site.
O.s. has several engines that would fit perfectly and aren't too expensive. Check on tower hobbies and you'll fid a few.
Thank you very much for the info ! still a bit lost to be honest, so many to choose from, do you know if this would fit 'Ofna Jammin .12 Pull Start ' im looking to spend around £80
could you tell me which o.s engines exactly, having trouble finding them lol
got another question. I only have 20% nitro fuel wich is great for my thunder tiger, tho not sure about the Schumacher nitro 10, wondering if it is called that because it takes 10% nitro, any ideas would be great
That's a good engine. I use too have one. Very reliable and easy too tune.Oli wrote:Thank you very much for the info ! still a bit lost to be honest, so many to choose from, do you know if this would fit 'Ofna Jammin .12 Pull Start ' im looking to spend around £80
You can run any of these smaller engines on 20%. The "10" in the name was for 1/10 scale.Oli wrote:got another question. I only have 20% nitro fuel wich is great for my thunder tiger, tho not sure about the Schumacher nitro 10, wondering if it is called that because it takes 10% nitro, any ideas would be great
thanks very much for answering all the questions!! been helpful
This one is a pretty good deal.http://www.nitrohouse.com/Picco-12-3-Port-Engine_p_8705.html
You're very welcome. Anytime.
that looks very good, do you have to buy the pull start?
- romulus22
- Has thanked: 900 times
- Been thanked: 789 times
Note the exhaust though. Some are rear exit and some are side exit. Make sure you can get a manifold in the style you are switching to if you switch exhaust style. I say this cause that's a rear exit engine and your car is most likely a side exit.
Also the carb style. If you have a rotary carb a slide carb may be difficult to to run your linkage to properly.
- Incredible_Serious
- Has thanked: 1737 times
- Been thanked: 1145 times
Which version Nitro 10 you have may change which engine you can fit easily*. The first versions were built specifically for the Irvine S15R (Mk1) or S15R2 (Mk2) engine, whereas the Mk3 was supplied with a Leo12 or Leo21 depending on model, or was provided with an engine mounting option kit (XR15, OPS15, NR15, MEGA15 / OS/LEO/TNT/YO 12 ps / OS/LEO/TNT/YO 12&15 no ps / ASP/SC 12 ps). The main difference is in the rear gearbox, and the chassis itself - the Mk3 has a slotted chassis to enable more engine options.Oli wrote:hi, I was recently given a Schumacher nitro 10, 1:10 and want to put a new engine in it, can anyone suggest one that is not too expensive,would love some advice.
I have manuals and many spare parts for these models, if you have a need....
* I say easily, if you're mechanically-minded enough you can make any engine fit, I guess.....
im pretty sure its the mk 3 I attached a pic, that's very kind. looking at the servo position I don't think a slide carb would work, not sure on the exhaust, I could possibly fit exhaust pipe manifold tho prob better not too, Oli
Hi, I have been told that this engine will drop straight into my Schumacher nitro 10 mk3 though would like a second opinion , 4476519 FORCE 18 CAR ABC S/EXH inc P/START (SG SHAFT)
SRP £62.99
SRP £62.99
Hi Alex, do you think this engine would drop straight in? 4476519 FORCE 18 CAR ABC S/EXH inc P/START (SG SHAFT)
SRP £62.99
SRP £62.99
Oli,Oli wrote:Hi Alex, do you think this engine would drop straight in? 4476519 FORCE 18 CAR ABC S/EXH inc P/START (SG SHAFT)
SRP £62.99
Don't have any experience with that particular engine unfortunately. From the pictures, it should be able to mount properly, pull start on the left, exhaust facing the rear of the car. You'll probably need to mix-and-match engine mounting kit bits to get everything to go correctly (engine mount blocks, clutch, throttle linkages, exhaust), but if you're willing to give it a go, you should be fine.
I'll be watching to see how you get on! Sorry I can't be much more help than that......
- 3042 Views
Last post by Welshy40
- 754 Views
- 964 Views
Last post by marty slater
- 3059 Views
Last post by DaveM
- 1913 Views
Last post by Bakauata
- 25 Replies
- 2346 Views
Last post by morrisey0
- 3108 Views
Last post by doldsen83
- 2312 Views
Last post by klavy69
