Yet Another RC10 CE Project!
protsi
Re: Yet Another RC10 CE Project!
Post by protsi »
mdutcher wrote:
protsi wrote:hi there! look really nice!!!!!
please can you show me how do you install the rear wing, and what wing mount are you using.
thanks in advance.
I got the idea from another member on this forum. Essentially, I am using standard RC10B4.1 wing mounts. Screw them into the shock tower, which BTW, mine are from RC Carbon Works and they come with holes already drilled into them. I just used on of the holes for each wing mount. The bottom of the wing mount will rest on the stealth tranny brace. This is where it doesn't look too professional, but it works for me. I then cut a hole in the back of the body to allow for the wing mounts to pop through.
Hope that this helps.
I am glad that you like the build. I am really digging these projects.
mmmmmmm...
I was thinking do the same but I believe if I drill a hole on the metal housing of the plate of the tranny and past true the holes frm the wing mount with a piece of metal tubing as a spacer its gone make it stronger ..... my 2 cent.
im on the process and I have the carbon tower as your but shorter version -3 mm im gone lower the body as much I cant to make it look sleeker like the new b4 also I try a b4 body and I cant make it look nice too will see later on hope everyone like it!!!!!!
im using v2 shock from b4 longer frt shorter back.
Users browsing this forum: No User AvatarAhrefs [Bot], No User AvatarAmazon [Bot], No User AvatarDotNetDotCom.org [Bot] and 5 guests
