Slipping Stealth - need a little help!
- RC104ever
Re: Slipping Stealth - need a little help!
I stand corrected, I popped the diff rings off and there were the diff balls. The gear is pretty gummed up so I think I will just get a new one along with new idler gear etc to rebuild it properly.
- Chris
Lots of cars...so many cars
- RC104ever
Here's another question for all of the experts: are there any other outdrives that will work for this tranny? Ie lightweight, Sc10 or B2/3/4?
Just wondering, Tower only shows the right od for some reason
- Chris
- Has thanked: 36 times
- Been thanked: 1318 times
the left outdrive is discontinued.
the were quite a few aftermarket outdrives back in the day. nothing currently being made.
you can't use any other outdrive that wasn't designed for the 2.25 stealth. b2, b3, b4, sc10...... none of those will fit.
- RC104ever
Well that sucks...was hoping for a full rebuild. So you can't substitute parts from a newer tranny to make the newer outdrives work?
What about this one:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LX3400&P=7
- Chris
- Charlie don't surf
- Has thanked: 356 times
- Been thanked: 470 times
-scr8p wrote:t
- RC104ever
http://www3.omnimodels.com/cgi-bin/woi0001p?&I=ASCC7678&P=FN
Would this kit work as a rebuild? States RC10 GT, but it all looks the same...what's the difference between the GT and the RC10 tranny if there is one?
- Chris
Charlie don't surf wrote:-scr8p wrote:t
the ratio of the lower gear, the size of the diff rings etc-
i can't see your picture anymore, but unless the outdrive slots are really chewed up or the threads are messed up, you don't really need to change the outdrives.
- RC104ever
Just wondering if this GT rebuild kit could work in my Stealth?
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXXH01&P=7
- Chris
- Eau Rouge
- Been thanked: 5 times
No, there is NOTHING on the market currently for the original Stealth gearbox. It's a vintage item needing vintage parts to rebuild or replace. There is no quick fix. If you want easy to buy parts, buy current race cars.
- RC104ever
Sorry if I annoyed you - I just like to ask a lot of questions and always want to know more about something.
If I can ask - why doesn't the GT rebuild kit work? It looks the exact same...is it the size of the diff gear? Or is it just the outdrives that are completely different?
I realize that there are lots of parts that cannot be easily obtained and I'm okay with that but at the same time, I would think that just because something wasn't originally designed for a car, doesn't mean that it wouldn't necessarily work.
I am relying on the folks here to steer me in the right direction and I apologize if the questions have been asked before!
- Chris
Chris, the only reason that you are annoying anyone that I can see is you have asked, and been answered the same question five different ways and had each one answered each time, but you still are asking the same question. They all look the same because they were all designed by the same group of people.
they look the same, but are just 'close' and 'close' won't cut it for substitute parts.
the original stealth had a 2.4:1(WRONG!! it's 2.25:1) ratio, where all the other currently available diffs are different ratios. the way they accomplished this is with larger differential gears. if they would have kept the rings and outdrives the same, and only changed the gear tooth count, we wouldn't have this problem. instead, and for specific reasons(more power handling is one major one) for every larger gear, they have different sized diff rings and corresponding outdrive hubs. so nothing cross-fits between ratios in the differential specifically.
if you were really resourceful and had the proper tools, I bet you could grind down a larger set of outdrives to fit into the 2.25:1 gear and diff rings.
- 2397 Views
Last post by lmw94002
- 1192 Views
Last post by cbracken
- 1198 Views
Last post by Gtstwincam
- 844 Views
Last post by 8rad
- 1991 Views
Last post by tmail56
- 852 Views
Last post by wyldbill
- 1051 Views
Last post by TurboZar22
- 1688 Views
Last post by shorne
