Stealth transmission slipping problem
Gtstwincam
Post by Gtstwincam »
I have an RC10 B3 with a stealth transmission. Installed a brushless system and the transmission slips bad. I tightened the slipper clutch all the way and it still slips.
With the slipper fully tightened and holding both wheels down, i can turn the spur gear, clutch assy in both directions. Not sure if something is wrong internally.
Anyone have any ideas?
RC10th
Has thanked: 52 times
Been thanked: 1548 times
Re: Stealth transmission slipping problem
Post by RC10th »
It could be one of two things, either the slipper clutch is slipping or the differential is slipping.
Can you determine which it is?
Gtstwincam
It was the differential slipping. I removed the rear right wheel, tightened it up a bit then backed off. Works! Now gotta work on the good pan
Users browsing this forum: No User AvatarBing [Bot] and 4 guests
