Gearbox slipping?
General info, Q&A.
bigdavevw
Gearbox slipping?
Post by bigdavevw »
Hi guys, the other day i took my 6 gear box apart and cleaned all the parts, i took real care putting everything back together. When i put the car back together and gave it some power it just seemed like it wasn,t putting the power down. Like in a car when the clutch is slipping??
I have had the gearbox apart twice now and followed the instruction manual, but it is still doing the same thing. The diff is set so that i can spin either tire with out the motor turning, whilst one tire is being held.
Can someone please help me with this cos i can think what it is.
Dave 8)
8rad
Has thanked: 9 times
Been thanked: 38 times
Re: Gearbox slipping?
Post by 8rad »
Thats your problem right there! If your holding one wheel the motor should spin when you turn the opposite wheel.
Put the car on the ground and tighten the diff 1/8th of a turn at a time until you are happy with the acceleration.
What turn motor are you using?
bigdavevw
Post by bigdavevw »
Hi 8rad, thanks for that, i tightened it some more and its not slipping! The motor i,m using is a Trinity speed gems 2 saphire 17X1
8rad
Post by 8rad »
8)
