Losi Slipper Spur question...
- JK Racing
- Has thanked: 139 times
- Been thanked: 246 times
Re: Losi Slipper Spur question...
A-3123 (slipper pads) X 2
A-3132 (slipper plates) X 2
A-3124 (spring & hardware) X 1
Spur of your choice
Spur of your choice
Just got my B4 slipper pads from Sr8p and try fitting it to a hydra top shaft and B4 slipper, amd it fits right in.
Will try to post some pics tomorrow.
― Confucius
― Confucius
- JK Racing
Yes, BTW, AE slipper plates and Losi slipper plates are interchangeable. I have AE plates on an LXT with a Losi spur....
so the answer is, yes.
yes, we can all get along
- sgirouard
Okay so the dummy of the group just showed up. LOL (me)
Can someone walk me through exactly what I'd need to do to make this happen with an original JRX2 gearbox and spur etc.
Do I need to change the spur gear shaft? Do I just need the slipper plates and pads etc like stated earlier? Sorry for being a noob on this but I really want to run brushless and want a real slipper.
- JK Racing
yes, you need the LXT, Pro SE slipper shaft for the LRM tranny (part # unknown by me)
the slipper parts I outlined above & current spur gear
gear cover made for a slipper set up
- bearrickster
Slipper Plates C/O Jason.
i have yet to check if my slipper orientation is correct, when i got the plates, i just yanked it in just for the fit, will check
later if its correct.
― Confucius
― Confucius
- JK Racing
hey jun, those dont look right, maybe you should send them to me for closer inspection
hahaha... im sure nothing that cant be fix......by a little trial and error...
My problem now is where will i get those RPM gear cover for Losi.... whaaaaaaa.......
will convert my ProT to a Buggy.....
― Confucius
― Confucius
- geeforce59
actually the slipper plates are for my RC10 Runner, it just so happens that when i got home yesterday i tried it and it fits perfectly on my Pro, will just buy another B4 slipper and put it on my Pro.
i have yet to check the performance when i placed it in my pro. Its been2 decades since i touched a Jrx2.
it slowly showing how old am i .....
― Confucius
― Confucius
So i tried installing my B4 Slipper plates to my Jrx2 Pro and have to remove some portion of the casings output hole for the backing plate not to bind with the casing. and below is the final results.
the clearance between the motor plate and backing plate is small, i wonder will this wobble on a BL powerplant.?
Tried experimenting on without removing (reaming) the tranny casings output shaft hole.
you can see the difference.
after reaming a portion of the casings output shafts hole. for the backing plate not to bind when in motion.
now i just have to find myself that RPM hydra cover for losi and AE hahahah...
― Confucius
― Confucius
- 836 Views
Last post by AustinZ
- 29 Replies
- 4393 Views
Last post by Mad Racer
- 1783 Views
- 955 Views
Last post by splaice
- 1313 Views
Last post by tecnica2001
- 1197 Views
Last post by TUCRACEMAN
- 552 Views
Last post by Brat
- 1200 Views
Last post by littleVETTE
Users browsing this forum: Bing [Bot] and 4 guests
