Hello all. It's been quite some time since i've been on this forum but I'm delighted to be back - the reason being that my two little boys and me are enjoying racing some vibtage RC10 buggies between us.
However, the 6 gear on one of the CEs that we are using has seen better days and i have a good stealth ready to fit. But it doesn't have a spur or slipper. Does anyone know if there are current slipper/spur (48 dp) bits that i can fit to an original stealth tranny?
Thanks in advance!
Replacement Stealth Slipper/Spur
- Been thanked: 19 times
Re: Replacement Stealth Slipper/Spur
Welcome back. The most common upgrade for this is to use a T4 top shaft (part #9601) with the modern slipper setup. This is also what was used on the modern RC10 re-release. Slipper pads are #9603, hubs #9604, and spring is #9605. It uses a standard 5-40 locknut to tighten it down. Several options for spur gear as well.
Current:RC10T, T3 FT, GT Blue Tub, GT FT, GT2 FT, GT5, RC28, SC28, Micro RS4.
Previous:B2, B3, B3 FT, 10T pink chassis, GT FT, TC3, TC3 FT, RS4MT
Tamiya TA02, Thunder Tiger TS4N pro, Kyosho VoneR, Emaxx, MX4, MP 7.5, 7.5 Kanai.
- Been thanked: 5 times
The challenge is that 9601s are like hen's teeth now. If they do turn up they are well over $40 shipped w tax etc, so it may be wiser to buy a complete used stealth which generally runs about $70
Big pile of RC10s and Ts from OG to 5s and an 18 or 3
Many thanks for the helpful responses. Do you know where i may easily find a 48dp 81 tooth spur gear that would fit both the 6 gear and the stealth transmissions? Associated, Kimbrough or Robinson Racing perhaps?
Thanks.
Thanks.
I generally get the spur gears from fleabay or hit up one of the RC10 fb groups
- 1608 Views
Last post by littleVETTE
- 23 Replies
- 3143 Views
Last post by JosephS
- 512 Views
- 1312 Views
Last post by tecnica2001
- 1672 Views
Last post by mdutcher
- 3238 Views
Last post by CBR240
- 34 Replies
- 3949 Views
Last post by RCveteran
- 29 Replies
- 4393 Views
Last post by Mad Racer
Users browsing this forum: Bing [Bot] and 3 guests
