RC10B3 Spur Gear Question
Dan442
Post by Dan442 »
Hello B3 folks,
Does anyone know if the older RRP #178X spur gears fit a B3? How about the current RRP #188X or #198X spur gears? These are all 48-pitch gears, right? I guess I'm curious about the hub size and the two mounting hole centers. Thanks for any help - I appreciate it!
-Dan
RichieRich
Has thanked: 39 times
Been thanked: 25 times
Re: RC10B3 Spur Gear Question
Post by RichieRich »
I use the RR absolute spurs and the stealth pros. I think those are the #178X and #188X ones.
Dan442
Post by Dan442 »
RichieRich,
Thanks for the info!
-Dan
dldiaz
Has thanked: 41 times
Been thanked: 58 times
Post by dldiaz »
Regarding the RRP "Absolute" spur gears - the ones that come with a small metal ring and a little rubber pad that goes under it... What is the correct mounting orientation of this gear assembly?
Does the metal ring face towards the slipper clutch? :?: :|
Or, does the metal ring face out towards the two mounting screws?
-dldiaz
TUCRACEMAN
Post by TUCRACEMAN »
dldiaz wrote:Regarding the RRP "Absolute" spur gears - the ones that come with a small metal ring and a little rubber pad that goes under it... What is the correct mounting orientation of this gear assembly?
Metal ring will face towards the mounting screws. Or be on the right side of the spur when looking from behind.
~D
No, I will not help you with your dorky short course truck…sorry, it’s against my religion. If it's not a 1/10 scale buggy...I don't care.
dldiaz
Post by dldiaz »
TUCRACEMAN wrote: Metal ring will face towards the mounting screws. Or be on the right side of the spur when looking from behind.
~D
Thanks!
-dldiaz
TUCRACEMAN
~D
Thanks!
Anytime!
Users browsing this forum: No User AvatarAmazon [Bot] and 4 guests
