Stealth Tranny and Brushless?
- Lowgear
- Has thanked: 121 times
- Been thanked: 795 times
Re: Stealth Tranny and Brushless?
So let me get this straight. To use a B4/T4 slipper on the RPM trans you buy this http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=320597908211 and switch the gears between topshafts?
- Charlie don't surf
- Has thanked: 356 times
- Been thanked: 470 times
- Group B
I was thinking of freezing spray (duster can upside-down) on the shaft, and some heat on the gear (a la butane torch/heat gun) to try to help get the gear off? Or does that method only work if one has dry ice?
I've never done something like that before!
- Lowgear
Nice, I'll have to try it. Now like Group B asked whats the best method of doing so?Charlie don't surf wrote:Yup, you can press off the gear, and re seat the other gear-
This is something i would like to see the end result.
― Confucius
― Confucius
- slotcarrod
- Been thanked: 45 times
Me too!
Rod Littau
I believe if you the right stuff and patience and also the skills, this would look like a piece of cake, but for me i think it would be difficult.
― Confucius
― Confucius
- Lowgear
I suppose how I would try it is to buy one of the many gear pullers off of eBay. If the gear wouldn't come off with the puller alone I might gently heat the gear with a butane torch. Then to press it on the new shaft I would start it by hand and then use the vise and a hammer. I would open the vise jaws just enough to let the shaft through but not the gear. I would then spray some WD-40 or equivalent on the shaft and gently tap it with the hammer until it went through the gear to where it needed to be.
Lowgear,
Will be ready to buy one from you when yours is done
― Confucius
― Confucius
all you should need is a vice, and some small sockets and round stock to push in the appropriate areas, and just press the gear off one, then press the gear onto the new shaft.....
have you done yours?can you show us your masterpiece,..Lowgear wrote:I suppose how I would try it is to buy one of the many gear pullers off of eBay. If the gear wouldn't come off with the puller alone I might gently heat the gear with a butane torch. Then to press it on the new shaft I would start it by hand and then use the vise and a hammer. I would open the vise jaws just enough to let the shaft through but not the gear. I would then spray some WD-40 or equivalent on the shaft and gently tap it with the hammer until it went through the gear to where it needed to be.
― Confucius
― Confucius
hope you did some extra? for meCharlie don't surf wrote:I have a few coming, get up with me in a few weeks
let me know when yours is done and available.
thanks,
― Confucius
― Confucius
how are you guys gearing the 10t with a normal stealth w/b4 top shaft?
i too, like the op, am running a 8.5t.
thanks
thanks
- 21 Replies
- 2037 Views
Last post by longboardnj
- 945 Views
Last post by Headling
- 395 Views
- 21 Replies
- 2553 Views
Last post by bigtenuk
- 2525 Views
Last post by Whiskers
- 1093 Views
Last post by Dave145
- 853 Views
- 995 Views
Last post by Bugle
