Stealth Tranny Questions
- Has thanked: 5 times
What is the difference between the original stealth tranny and the T2/T3 tranny? I have been told it’s the gear case and the diff gear? Is that the same as a Losi XXX-T too?
Re: Stealth Tranny Questions
yes they are all similar in being three gear, but more than half of parts are different. Different trans case, diff gear, rings, idler gear, motor plate. The top shafts can swap; bearings, diff balls and thrust assembly also all cross between versions. This goes essentially for rc10 all the way through to B4, before they had a gear diff available.
I assume it's very similar for losi but that's a completely different company and design.
- 395 Views
- 582 Views
Last post by JPAE07
- 987 Views
Last post by highwayracer
- 892 Views
Last post by henry
- 21 Replies
- 1962 Views
Last post by knucklebuster
- 1129 Views
Last post by Boredome
- 995 Views
Last post by Bugle
- 1280 Views
Last post by badhoopty
