Transmission Internal Drive Ratios
- RogueIV
- Has thanked: 1875 times
- Been thanked: 888 times
Re: Transmission Internal Drive Ratios
Ultima rere is 3.79:1
- Lowgear
- Has thanked: 120 times
- Been thanked: 754 times
Updated the list with the new info.
I also noticed the 'RPM Stealth Truck Conversion (white case)' was wrong so I fixed that too.
- dldiaz
- Has thanked: 41 times
- Been thanked: 58 times
Holy Cow?!
I assume this would apply to the '87 JJ Ultima, as well?
Man, it will be hard to find a pinion gear big enough to optimize a 21.5 setup!
-dldiaz
- Has thanked: 1105 times
- Been thanked: 601 times
Kyosho offers a 51t spur gear for brushless motors. Stock is 57t. OTW126B
-Brad
- Has thanked: 59 times
- Been thanked: 109 times
- RogueIV
The ratio isn't so bad once you realize that the spurs for it are way smaller than other transmissionsBattleTrak wrote: ↑Mon Nov 25, 2024 11:18 pmKyosho offers a 51t spur gear for brushless motors. Stock is 57t. OTW126B
- Has thanked: 647 times
- Been thanked: 462 times
Yep it gives you more options for sure.BattleTrak wrote: ↑Mon Nov 25, 2024 11:18 pmKyosho offers a 51t spur gear for brushless motors. Stock is 57t. OTW126B
- Has thanked: 1670 times
- Been thanked: 797 times
Schumacher Top Cat / Cougar original or re-release standard transmission: 2.43
Schumacher Top Cat / Cougar re-re U7600 Pro transmission: 2.07
- TRX-1-3
- Has thanked: 1932 times
- Been thanked: 940 times
- Has thanked: 46 times
- Been thanked: 104 times
Same as Rustler / Bandit / Stampede, since the internals are interchangeable.
*** POWDER - KING ***
Cougar 2000 2.0:1 (same gearbox as Storm 2000)
Pro CAT 2.53:1
XLS/Pro CAT re-release U7236 Pro transmission 2.4:1
Bosscat 2.43:1
Pro CAT 2.53:1
Bosscat 2.43:1
- 1118 Views
Last post by templeofspeed
- 2622 Views
Last post by TheDiamondOne
- 2017 Views
Last post by polarbear
- 393 Views
Last post by fakiee
- 2778 Views
Last post by Lou0151
- 1273 Views
Last post by Rattlesnaker
- 3437 Views
Last post by teman
- 1430 Views
Last post by ericsp2
Google Feedfetcher,
mikea96 and 6 guests
