Ten4: the 4WD RC10 project
mk-Zero
Business Member
Has thanked: 4 times
Been thanked: 21 times
Re: 4WD RC10 project
Post by mk-Zero »
n20capri wrote:
mk-Zero wrote:Thanks Rod. Next up is a mid-motor 4WD RC10 8)
I'm down for helping out any way I can...This is what I want to do...
Should be pretty easy, the hard part of the 4wd conversion is in the front of the car, and all that will be the same between the rear and mid motor versions :wink:
n20capri
Post by n20capri »
Just saying! :)
I guess you'll build one of your cool stealth cases to just position the output shaft higher up??
mk-Zero
Business Member
Post by mk-Zero »
Maybe, we'll see ;)
back in the day, the mid motor, belt drive 4wd rc10 was called the yokomo yz10 :lol:
Phin
Has thanked: 87 times
Been thanked: 248 times
Post by Phin »
Hardest part about mid-motor 4wd for me was maintaining the resemblance of an RC10. My ideas for it always get too far away from the original design. :?
mk-Zero
Business Member
Post by mk-Zero »
Yesterday I designed up some new extended steering bell cranks real quick (to make up for the nose being in the long position). I left the boss for the servo connection off the left one because I was in a hurry and more concerned about checking clearance with the transmission case. I printed a set, in red for fun:
Testing them on the car, I immediately saw the link between the arms would interfere with the trans case, so I drilled a hole on each back a few tenths. Test fitting again and it fit perfectly. Next I need to assemble the steering on the right side of the car and see what the ackerman is doing. Depending on that I may need to tweak them and/or the steering blocks a little more.
Phin
Post by Phin »
Maybe someone could let you borrow a Winning Edge Pro-Steer kit for you to 3D print. Would be a neat steering solution for a 4wd car.
mk-Zero
Business Member
Post by mk-Zero »
That's a cool setup! I think the bell cranks are going to work fine though. ;)
mk-Zero
Business Member
Post by mk-Zero »
Next iteration
They work great. Still need to check ackerman though.
Sure is nice not having to wait 3 weeks to test every design change, lol.
fredswain
Post by fredswain »
Which 3D printer did you get?
mk-Zero
Business Member
Post by mk-Zero »
FlashForge Creator Pro
mk-Zero
Business Member
Post by mk-Zero »
Today i designed and printed a front belt guide/tensioner. It seemed to work pretty well.
next i need to finish designing the rear bulkhead with built in belt guide mounting. That's about the last major piece for me. Still hoping to wrap this thing up by the end of May.
variant45
Post by variant45 »
I like your design idea of the belt guide/tensioner.
Scott
mk-Zero
Business Member
Post by mk-Zero »
Thank you. I like to keep things simple, and I think this will do the trick.
Beau S
Post by Beau S »
Phin wrote:Maybe someone could let you borrow a Winning Edge Pro-Steer kit for you to 3D print. Would be a neat steering solution for a 4wd car.
A group of us tried them back-in-the-day, cool concept, but super fragile & easly clogged with dirt.
