RC10 Team Car Setup for 2008 Vintage Off-Road Champships
- Has thanked: 11 times
- Been thanked: 24 times
Mark Westerfield's
2008 Vintage Off-Road Nationals @ Radio Control Hobbies & Raceway, CT.
1991 RC10 Team Car Setup
Front
Shock Body: .71
Shock Shaft: .71
Travel Limiter: None
Piston: #1
Oil: Asc 40wt
Spring: Green
Shock Upper Mount: Top Middle
Shock Lower Mount: Arm Outside
Camber Link: Inside
Camber: -1.5 Degrees
Castor: 30 Degrees
Toe-In: 0 Degrees
Bump Steer: 2 x .030 on steering block
Bellcrank Type: Houge Ball Bearing
Steering blocks: Inline
Front Axle: T4 Inline
Ride Height: 22mm
Wheels: RC10B4
Tires: JConcepts Rounders
Inserts: JConcepts Standard
Rear
Shock Body: 1.32
Shock Shaft: 1.32
Travel Limiter: 3 x .125
Piston: #1
Oil: Asc 35wt
Spring: Green
Shock Upper Mount: Inside
Shock Lower Mount: Outside
Camber Link: Inside Under Wing Mounts
Anti-Squat: Std (3 Degrees)
Toe-in: 1.5 Degrees On Mount, 1.5 Degrees On Hub Carrier
Wheelbase: Short
Rear Axle: MIP RC10 CVD's W/RC10B4 CVD Axle, B4 wheel spacers, 3/8 x 3/16 Flanged Bearings
Ride Height: 22mm
Wheels: Duratrax Nitro Evader
Tires: JConcepts Double Dee's
Motor: Novak 17.5
Gear Ratio: 28/81
Battery: Orion 3200 Lipo
Speedo: LRP Sphere Competition
Settings: 1-4-1-3
Servo: Airtronics 94357
Body: Asc Viper
Wing: Asc 6.5 w/ Full Spoiler
Other tips...
If using the graphite trasmission brace, make sure the .060 washers are between the the bulkhead and brace. Use a striaghtedge to make sure the chassis is striaght across the bottom for correct front kickup and rear antisquat. Add shims between motor guard and chassis to correct antisquat. Use short neck ballstuds on steering rack and front shock tower to eliminated ballcup contact. Final tuning on these cars is mostly done with shock limiting and ride height adjustments.
Front
Shock Body: .71
Shock Shaft: .71
Piston: #1
Oil: Asc 40wt
Spring: Green
Camber Link: Inside
Castor: 30 Degrees
Toe-In: 0 Degrees
Ride Height: 22mm
Wheels: RC10B4
Rear
Shock Body: 1.32
Shock Shaft: 1.32
Piston: #1
Oil: Asc 35wt
Spring: Green
Wheelbase: Short
Ride Height: 22mm
Motor: Novak 17.5
Gear Ratio: 28/81
Settings: 1-4-1-3
Body: Asc Viper
Other tips...
- Has thanked: 7 times
- Been thanked: 41 times
Re: RC10 Team Car Setup for 2008 Vintage Off-Road Champships
Hey Mark,
Nice job on giving the guys a place to start with their setup, seems from looking at the video that it's a pretty forgiving setup as well. One thing I would suggest (picking nits here...) If you use 1.02 shafts in the rear you'll achieve 2 things: fewer spacers on the shaft to get the correct down travel and the piston will stay completely in the oil with the shorter shaft since it won't travel up as far into the shock body. It's by no means a necessity though, just something that crossed my mind when I saw your internal limiting values.
I wish I could attend this race myself but I'm going to be out of town on a long previously scheduled trip
Have a great time!
Have a great time!
- RichieRich
- Has thanked: 34 times
- Been thanked: 19 times
How do we know if we need the washers? I swear some of the bulkheads have different heights.Mark Westerfield wrote:Mark Westerfield's
The oil mixes with the air and is emulsified with either shaft length with the amount of turbulance the piston causes, so it really dosen't matter which shaft you use. Most racers pump their shocks a few times before the race to pre-mix the air and oil for consistancy.
Oh yeah, I'm using Yokomo bleeder shock caps - forgot to put that in the setup.
Another trick is make sure the top and bottom coils on the springs are sperated and not powder coated together as this changes their spring rate. Use Brian Kinwald's spring grinding tip to ensure the springs do not rub the shock bodies during travel...
http://www.2wdrc.com/DDP/SpringAdjusting.htm
If your using the graphite brace on the AE Stealth transmission, then you need them. If you look very closely at the very top of the Stealth Transmission (especially if its out of the car on a flat surface), you'll see that the top of the transmission is not perfectly level and leans back, because of this, you need the washers. The effect is that the transmission pulls on the chassis plate and reduces the antisquat (checked with a straightedge on the bottom of the chassis)RichieRich wrote: How do we know if we need the washers? I swear some of the bulkheads have different heights.
- carloco8
- Has thanked: 10 times
- Been thanked: 27 times
The bulkheads with the the 9-hole camber link square need the .060 washers. The "world's" bulkhead with only three camber link holes on the outside has extra plastic molded on top and doesn't need them.
- Has thanked: 19 times
- Been thanked: 29 times
Hey Mark, have you tried fitting anything larger than a 3200 pack, will a 4500 pack fit in the RC10??
I have a worlds bulkhead on my car and still needed the spacers to keep the chassis straight and true for correct anti-squat. The main goal is to keep the chassis straight, unless your doing a "by the book" restoration.carloco8 wrote:The bulkheads with the the 9-hole camber link square need the .060 washers. The "world's" bulkhead with only three camber link holes on the outside has extra plastic molded on top and doesn't need them.
I had to drill holes in the chassis for the battery cup to compensate for the length of the Orion 3200 lipo. The Orion 4800 and the Reedy 5000 both fit, although the screws that hold the battery strap in needed to be raised. I choose the Orion 3200 because the race lengths at Vintage Nats is only 5 minutes, and the 3200 is lower in weight. You have to remember, my setup is based on the weight of the Orion 3200, heavier batteries might have undesired effects using my setup.tecnica2001 wrote:Hey Mark, have you tried fitting anything larger than a 3200 pack, will a 4500 pack fit in the RC10??
Your welcome.badhoopty wrote:man that helps a ton...
thanks mark!!!
Pictures of my car to follow soon...
- aeiou
Thanks for all the detail, Mark.
Are you running an original slipper on that car?
Mark,
Thanks for all the info. You shoud have told me that you posted the set-up here, then I wouldn't have palyed 20 questions with you at the shop yesterday.
Can you order me the parts needed to do the rear CVD conversion for Garys gold tub car? Let me know because I'll be putting a list of parts together that he need to get in addition to the axle conversion. I'm be sending him up next weekend to get what you have. I'll probably give you a call durring the week let you know what we need so you can hold them for us. He probably will be buying a few of the parts back from you that you bought from him yesterday....
Ron DePoto
Team Driver:
Schumacher / Speedpassion / Core RC / Express Motorsports / Dialed Inc. / ROAR Region 1 Director
Team Driver:
Yes, the original slipper. Your really not going to need a slipper clutch with a 17.5 and current compound tires on our track.aeiou wrote:Thanks for all the detail, Mark.
- 33 Replies
- 3837 Views
Last post by Bongo Fury
- 1824 Views
Last post by plasry
- 2610 Views
Last post by Sharkman
- 2152 Views
Last post by slotcarrod
- 42 Replies
- 5705 Views
Last post by Wicked6
- 2101 Views
Last post by flipwils11
- 4392 Views
- 2193 Views
Last post by RC10resto
Users browsing this forum: Amazon [Bot], Facebook [Bot] and 52 guests
