Reassembling a Kimbrough servo saver
Post Reply
Has thanked: 1589 times
Been thanked: 1770 times
I have a Kimbrough servo saver that popped open when I was removing the screw from it after taking it off a servo. Getting the spring back inside the 2 halves of the servo saver body can be really frustrating. However, there are some small holes near the spring stop feature. Running a piece of waxed dental floss (fishing line probably works too) through the spring and the holes allows you to pull the spring into place and hold it there while the servo side of the unit is added. The pic below shows the setup for this technique with a broken servo saver.
Post Reply
  • Direct mount servo saver on a metal gear servo??
    by SmallScaleSmitty » » in Modern Electronics
    Last post by SmallScaleSmitty
  • B2 servo saver
    by R Cane » » in Temple's RC10 Tech Forum
    Last post by Phin
  • T4 SERVO SAVER
    by longboardnj » » in 21st Century Modern
    Last post by PBR Allstar
  • 'Best' servo saver?
    by badhoopty » » in Modern Electronics
    Last post by badhoopty
  • Who needs a servo saver?
    by harvey » » in Temple's RC10 Tech Forum
    Last post by Lonestar
  • Servo saver conundrum....
    by SmallScaleSmitty » » in Associated On-Road Forum
  • I need a replacement servo saver
    by tbfoto » » in Temple's RC10 Tech Forum
    Last post by rcflyer1984
  • Rc10 servo saver?
    by joaquinva1 » » in Temple's RC10 Tech Forum
    Last post by joaquinva1
Users browsing this forum: No User AvatarBing [Bot], User avatarDangeruss and 19 guests
