B2 servo saver
- R Cane
- Has thanked: 155 times
- Been thanked: 63 times
B2 servo saver
The RC10B2 #9155 black servo saver parts - did anyone ever make an alloy upgrade?
If not, does anyone know of one made for different kit that would work?
- Has thanked: 822 times
- Been thanked: 2418 times
Re: B2 servo saver
Never seen a metal one but MIP had a very nice one
Factory Works website
- Has thanked: 35 times
- Been thanked: 10 times
Re: B2 servo saver
To the best of my knowledge no metal one.
You could check the Thunder Tiger ST/BX part, but that is quite different...
- RC10th
- Has thanked: 40 times
- Been thanked: 1015 times
Re: B2 servo saver
What's wrong with the stock plastic pieces?
- R Cane
Re: B2 servo saver
The last 2 stock sets I've gotten haven't impressed me much. One of the parts, when I popped it off of the "tree", left a chunk of the part still on the tree. Seemed very brittle, and didn't give me any confidence that it would take abuse from running the car...
Re: B2 servo saver
You can always get a shapeways drawing done as they now do alloy prints so may be worth a go.
Designer of the Lazer ZX / ZXR Tub Chassis (now available again from Fibre-Lyte)
Sponser links below
http://www.fibre-lyte.co.uk/
http://www.kamtec.co.uk/
Sponser links below
- yellowdatsun
Re: B2 servo saver
Can you not use parts from another car in the RC10 family? So many parts either interchange, or can be modified slightly to work.
- R Cane
Re: B2 servo saver
I have multiples of the earlier metal pan RC10's, and I know no of those will work on the B2. I don't have any of the newer ones (yet), so I didn't know if any of those were workable.
- Phin
- Has thanked: 61 times
- Been thanked: 182 times
Re: B2 servo saver
Are the B2's shorter than an RC10's servo saver? I bought a set of GPM cranks for a Losi Street Weapon to use on a RC10 Terminator build that I wanted to rotate the servo on. The holes were pretty close:
You might also be able to mode the SW cranks to work. Add new holes/file them down. For ~$7 shipped they might be worth a try.
http://www.ebay.com/itm/GPM-Racing-Losi-Street-Weapon-Purple-Aluminum-Steering-Set-XX4807-/381548011602?hash=item58d608a052:g:iGsAAOSwx-9WxAU0
One note though...I think the bearings for the SW cranks are 8mm outer diameter. Close enough to 5/16" that you can use them though.
- 564 Views
Last post by SmallScaleSmitty
- 783 Views
Last post by PBR Allstar
- 423 Views
Last post by badhoopty
- 747 Views
Last post by Lonestar
- 2420 Views
Last post by joaquinva1
- 537 Views
- 7772 Views
Last post by cmain
- 859 Views
Last post by rcflyer1984
