TQ10 resto
- Has thanked: 8 times
- Been thanked: 77 times
TQ10 resto
Back at the work bench after a hiatus while building a house and then messing around with HO slot cars over the past few years. I started to restore this TQ10 several years ago but never got past tear down. I did collect a few NIB parts back then, so I'll try to get this one in nice shape without using any re-re parts. The goal to get it to the rolling chassis stage before spring.
The previous owner drilled the chassis (poorly) for a stealth trans at some point. I'll fill the holes and clean up the chassis a bit. I guess this would be considered a mid-production chassis, as it is drilled for the motor guard.
Kyosho, JRX-2, Gold Tub Fan
Re: TQ10 resto
I moved into a new house and have not fully unpacked all the RC stuff after the move. The bin that I stored the torn down buggy in was missing many parts, so I've been digging through moving boxes over the past week looking for the rest of the car.
It's funny (and a bit sad) when I find cars/parts/tools that I have forgotten about. My wife says I'm like a kid at Christmas as I dig through the stash. High five!
Found an RC10 graphite and will probably build that next.
I think the arms, shocks, towers etc may be in here somewhere... Gold pans!
This bin is looking promising... This bin will be helpful, too.
I think the gold motor plate I had in the TQ10 bin is not correct. This 6 gear with a black ano motorplate seems to be the correct trans for a TQ10.
- MarkyDents
- Has thanked: 1361 times
- Been thanked: 511 times
Re: TQ10 resto
Looks like you’ve got lots of parts to work with. Nice
Yes the black 6 gear only motor plate would be correct for the TQ10.
Hey Cru ! Go balls out
Re: TQ10 resto
Thanks for confirming!MarkyDents wrote: ↑Sat Jan 13, 2024 6:52 pm Looks like you’ve got lots of parts to work with. Nice
This 6 gear seems to have a bunch of hours on it. I don't have a lot of history with the RC10, but this is the most wear I've seen in my experience.
The outdrives are beat!
The motor plate has some wheelie wear. I hate to do it, but will probably need to paint it.
- MarkyDents
Re: TQ10 resto
Considering how well the motor guard covers it, I wouldn’t paint it. For me it’s also the fact that it’s a TQ10 only piece.
- juicedcoupe
- Has thanked: 231 times
- Been thanked: 1747 times
Re: TQ10 resto
For stuff like that, I usually just touch it up with a black Sharpie.
If you know it's there, it's still obvious. Otherwise, people aren't likely to notice it.
- Has thanked: 1013 times
- Been thanked: 472 times
Re: TQ10 resto
You could always just cut a the plate down to where the anodizing is good. Tucked behind the motor guard and screwed in it will look proper.
- sandkil
- Has thanked: 670 times
- Been thanked: 462 times
Re: TQ10 resto
Small scratches can be fixed with Birchwood Casey Aluminum black.
Clean surface with acetone.
Apply Aluminum Black with a cotton bud or brush.
Rinse with water.
Polish with dremel and cotton wheel.
Rinse with water.
Re: TQ10 resto
Good ideas, thanks!
I tested a semi-gloss paint pen and the results look decent. I'll test the Birchwood stuff, too, as I have a few other things in the safe that could use some touch up.
Inspecting some nylon to see which is the prettiest... I may need to peroxide a few pieces a bit.
Re: TQ10 resto
Separating the good from the not so good. My shock inventory is in poorer shape than I recall.... These are all the bottom loaders I have. There are two new 1.32 bodies and a couple decent .56s. None of the shock caps are perfect.
Re: TQ10 resto
good eye!
Thanks for the info. Will be on the lookout at the sporting goods store.
- Frankentruck
- Has thanked: 1589 times
- Been thanked: 1770 times
Re: TQ10 resto
You might be onto something. Having a body pin holder when the top is off would be unique.
- 2868 Views
Last post by Asso_man!
- 1575 Views
Last post by rctenracer
- 811 Views
Last post by XxRONNxX
- 1178 Views
- 1246 Views
Last post by teman
- 1306 Views
Last post by Volumiza
- 328 Views
- 483 Views
Last post by RedScampi
Users browsing this forum: Facebook [Bot] and 37 guests
