My TQ10
- teman
- Been thanked: 6 times
My TQ10
Here's the build start after the disassembly, cleaning process and chassis prep I know it isn't much at the moment, but the new graphite towers will replace the originals along with anything that needs the some attention. Stay tuned, much thanks goes out to Don!
-Kevin
- Been thanked: 22 times
- Asso_man!
- Has thanked: 40 times
- Been thanked: 70 times
Re: My TQ10
Nice! Did you sand the chassis? Looks like an early one without the rear motor guard holes.
Come and visit the stable
- teman
Re: My TQ10
I was holding out for a new sidewinder to pop up but I became impatient A few more bits are coming this week, I'm hoping to have everything done in the next couple of weeks. I don't plan on changing too much... just wheels, turnbuckles and steering.THUNDERSTRIKE1 wrote:Cool about time you found time to rebuild and restyle her . don
Yeah, the nose front left was delaminating so I felt compelled to do something about it. After fixing that I figured I might as well attempt to take the scratches out of it. As you probably know it makes the finish look dull, I bathed it in some shock oil to bring the sheen back to it rather than clear coating it. I may try plasti dip, haven't decided quite yet.Asso_man! wrote:Nice! Did you sand the chassis? Looks like an early one without the rear motor guard holes.
About the motor guard and holes, I guess I'm going to leave it as is since I don't think I'm going run this one.
-Kevin
- slotcarrod
- Been thanked: 41 times
Re: My TQ10
Why is the chassis so wavy at the kick up?
Rod Littau
- teman
Re: My TQ10
Good question, I don't know. I do know the camera flash makes it look even more strange than it really is. Maybe something to do with how the the nose is heated and then stamped for the kick-up? No idea really, just guessingslotcarrod wrote:Why is the chassis so wavy at the kick up?
-Kevin
- teman
Re: My TQ10
Reassembled now minus electronics Onto the body next, almost ruined it in the mounting process due to the area in the rear where it was paper thin I had to flip the transmission brace around just to make it work Keep that in mind if you buy this body. More about that later, I'll be designing and painting the body next week sometime and take more photos.
-Kevin
Re: My TQ10
I have 2 those white spring spacers about the size those black ones on top the front spring clamp,if need them .DON
Re: My TQ10
The wavy look is the internal carbon fiber modulus. They're all a bit different, but uni-directional carbon fiber matting/fabric is "laid up" and then resin is applied and heated to make a composite out of the ingredients. The wave is the reflection of fibers that didn't stay straight during any step leading up to the curing of the material, like bunching, snags and such. CF/Graphite is only heated or cured once, it's a chemical and physical change after that it's done...can't be un-done or re-done. The panels were made with that angle in the mold/vaccum bag during the curing process, then cut as one unit (early chassis, like yours were flat routed, then fixed at the nose and routed, then drilled. Look @ the cut lines at the nose area near the belcranks on the side of the chassis) Later TQ10's used a different top layer of uni directional fabric, more of a pre-preg material, so they lost that sheen and were uniform in look, also a 3 axis router cut them in one operation, so the "flat" cut on the early noses went to a "sharp" cut on the later noses. Nerd-rant overteman wrote:Good question, I don't know. I do know the camera flash makes it look even more strange than it really is. Maybe something to do with how the the nose is heated and then stamped for the kick-up? No idea really, just guessingslotcarrod wrote:Why is the chassis so wavy at the kick up?
- teman
Re: My TQ10
Thanks Reggie, very interesting information. You don't really see it when the tower and mounts are bolted up so out of sight out of mind I'm happy with it and it's nice to look at
I drew up the masks, cut and applied them. Hoping to finalize the design, I may just paint it black and do vinyl pinstripe work since the body is just so paper thin in certain areas - well that and it doesn't seem to fit quite right either Maybe some day I'll stumble across an original.
-Kevin
- 240 Views
Last post by brn2fly
- 811 Views
Last post by XxRONNxX
- 483 Views
Last post by RedScampi
- 1179 Views
Last post by Asso_man!
- 1307 Views
Last post by Volumiza
- 328 Views
- 1575 Views
Last post by rctenracer
- 1974 Views
Users browsing this forum: Amazon [Bot], Tbot [Bot] and 36 guests
