Does anyone know if the outer piece of a XXX-S and a XXX-4 Front axle are the same.
I know they have different part # in the manual ,but I'm thinking that's because they are sold as axle sets.
Thanks for any help.
XXX-4 Front axle
- RogueIV
- Has thanked: 1119 times
- Been thanked: 459 times
Re: XXX-4 Front axle
I can measure them when i get home but I'm pretty sure they are different. The steering knuckle on the xxxs is wider and the hex is removable without taking the pin out. The xxx4 the axle is shorter and the hex is reverse mounted and captured by the pin.
- RogueIV
The only difference seems to be a slight shorter amount of threads. The XXX-S stub axle has 7mm of threads where the XXX-4 only has 5.5mm of them. You shouldn't have any issue running XXX-S stub axles on the XXX-4.
- Regular Member
Somewhat related question...
Does the JRX-S LCD rebuild kit fit the XXX-4 LCDs?
Looking at pics, the axle and bone interface look the same, but the JRX barrel looks much shorter. Is that an illusion because it is also thicker than the X4 version?
- 1060 Views
Last post by Bottom Feeder
- 564 Views
Last post by highwayracer
- 492 Views
Last post by folkdeath95
- 2069 Views
Last post by JK Racing
- 1204 Views
Last post by rccars4sal
- 662 Views
Last post by burnsmonkey
- 28 Replies
- 1647 Views
- 1099 Views
Last post by fst72vette
Users browsing this forum: No registered users and 13 guests
