Attaching Steering Servos to a rc10 pan chassis
- Has thanked: 1013 times
- Been thanked: 472 times
I'm building a rc10 DS in one of the new 6001 gold pans.
I was considering replacing the GT style bell cranks with b2 style so I could free up some space to move the electronics forward.
Is this a bad idea?
Are there any ways to do this without drilling holes in the chassis?
Is there a strong enough tape or velcro to hold down the servo?
Has anyone tried using CA or epoxy to secure servo mounting blocks?
I can either switch up chassis to one with some already installed bonus holes, or just mount the servo the boring normal way if that doesn't work out.
Is this a bad idea?
- Has thanked: 946 times
- Been thanked: 563 times
Re: Attaching Steering Servos to a rc10 pan chassis
The ultimate Velcro is 3M Dual Lock. It locks down solid with minimal twist and movement.
-Brad
Would that be enough for an onroad steering servo?BattleTrak wrote: ↑Sun Aug 13, 2023 1:54 am The ultimate Velcro is 3M Dual Lock. It locks down solid with minimal twist and movement.
There will be very slight movement.. not as good as solid posts of course, but better than servo tapes & industrial Velcro.JosephS wrote: ↑Sun Aug 13, 2023 2:52 amWould that be enough for an onroad steering servo?BattleTrak wrote: ↑Sun Aug 13, 2023 1:54 am The ultimate Velcro is 3M Dual Lock. It locks down solid with minimal twist and movement.
-Brad
- juicedcoupe
- Has thanked: 231 times
- Been thanked: 1747 times
One problem that you may run into is clearance between the bellcranks and the chassis. The shape of B2 bellcranks is a little bulkier than other types.
- Frankentruck
- Has thanked: 1589 times
- Been thanked: 1770 times
If you have an idea of how you want it positioned I might be able to 3D print you a mount that uses existing chassis holes.
- juicedcoupe
Since it's for an on-road application, perhaps a mini servo could be used as well.Frankentruck wrote: ↑Sun Aug 13, 2023 6:48 am If you have an idea of how you want it positioned I might be able to 3D print you a mount that uses existing chassis holes.
Maybe something as simple as a plate that attaches to the chassis, with new transverse holes. The lower profile of a mini servo would offset the added height of the adapter plate.
- Has thanked: 191 times
- Been thanked: 16 times
I have attached servo's with servo tape to my on road and off road chassis without issue.
I also attach my battery cups with it.
Using 3M VHB tape currently.
Thanks. Where do you get yours from? What model number are you using? I see some pretty large price disparities on Amazon based on model number.
Thanks.That is a great thought. I could just make a small plate adapter out of kydex or carbon fiber that I could attach to the existing chassis holes and some servo mounts.Frankentruck wrote: ↑Sun Aug 13, 2023 6:48 am If you have an idea of how you want it positioned I might be able to 3D print you a mount that uses existing chassis holes.
I did notice that. I was planning on using a small washer or thick tape to handle that.juicedcoupe wrote: ↑Sun Aug 13, 2023 6:02 am One problem that you may run into is clearance between the bellcranks and the chassis. The shape of B2 bellcranks is a little bulkier than other types.
- juicedcoupe
They are also bulkier on the side. They will somewhat limit steering travel by hitting the side of the pan.JosephS wrote: ↑Sun Aug 13, 2023 12:24 pmI did notice that. I was planning on using a small washer or thick tape to handle that.juicedcoupe wrote: ↑Sun Aug 13, 2023 6:02 am One problem that you may run into is clearance between the bellcranks and the chassis. The shape of B2 bellcranks is a little bulkier than other types.
https://www.mcmaster.com/catalog/129/3899/8127A531
That might be an issue, but it could work. Measurement wise they seem similar width to the gt style pieces. The top of the arm seem like it could be an issue hitting the chassis.juicedcoupe wrote: ↑Sun Aug 13, 2023 12:53 pmThey are also bulkier on the side. They will somewhat limit steering travel by hitting the side of the pan.JosephS wrote: ↑Sun Aug 13, 2023 12:24 pmI did notice that. I was planning on using a small washer or thick tape to handle that.juicedcoupe wrote: ↑Sun Aug 13, 2023 6:02 am One problem that you may run into is clearance between the bellcranks and the chassis. The shape of B2 bellcranks is a little bulkier than other types.
- MarkyDents
- Has thanked: 1361 times
- Been thanked: 511 times
Argggg I want to click the pics for clarity but it won’t work…. Why does this happen sometimes !?!
Last post I made with a couple pics the last one did this. I know I placed them all inline in the single post
Hey Cru ! Go balls out
- 44 Replies
- 5272 Views
Last post by CAT3K
- 5185 Views
Last post by Frankentruck
- 1575 Views
Last post by njdriver04
- 637 Views
Last post by THEYTOOKMYTHUMB
- 22 Replies
- 583 Views
Last post by duckhead
- 1773 Views
Last post by Dave145
- 1475 Views
Last post by janaya
- 790 Views
