Associated 05 modified
- Lavigna
- Has thanked: 797 times
- Been thanked: 1041 times
Re: Associated 05 modified
This one is similar. Not sure of anything more.
My Photo Gallery --->https://www.rc10talk.com/viewtopic.php?f=77&t=38934
- Has thanked: 2287 times
- Been thanked: 1994 times
You see 05 on the label on many motors. Kyosho, Jerobee, Reedy. It must have a meaning? Five minute motor class?
- Has thanked: 822 times
- Been thanked: 2418 times
.05 was a rating given to the 540 class motors back in the day. I suspect it was a rough comparison of its power to a nitro engine. There were many other sizes, Astroflite for example had .035’s, .05’s, and 40’s.
Factory Works website
- dinglem
- Has thanked: 243 times
- Been thanked: 629 times
Directly quoting a previous post from motor guru Mike Haswell.... '...when they ran 1/12th with gas/IC engines they couldn't exceed 0.5 size engines (most ran with 0.49) and then when electric came along that was the term coined for the motors that met with the ROAR regulations for the class as most had crossed over from gas.'
I have seen many Igarashi-based Associated Reedy modified 05 motors, but this is a cross-over label from when the early Yokomo motors were released. I have seen these in this format before, although not many. I am assuming this must have been a brief period before the Reedy labels as we now know them appeared.
- Has thanked: 191 times
- Been thanked: 16 times
I see there's a similar motor currently on eBay, same label, but it has a black can, bearings, and adjustable timing. This one looks like the stock Yokomo motors that came in the rc10 with a different label. Might be what it is.
- Phin
- Has thanked: 61 times
- Been thanked: 182 times
It's no real help figuring out turns/winds, but there are 3 Reedy "Modified 05" motors listed in the Edinger Catalog:
#6505 called a Club Racer
#6510 called a Standard
#6511 called a Sprint (for dirt oval tracks)
In the Cadillac catalog #6510 is renamed to Road, and #6511 to Oval.
- 20 Replies
- 2288 Views
Last post by Bent
- 3598 Views
Last post by Wahrsuul
- 728 Views
- 1222 Views
Last post by terry.sc
- 1348 Views
Last post by blubblood
- 3413 Views
Last post by Dadio
- 1662 Views
Last post by dinglem
- 896 Views
Last post by juicedcoupe
Users browsing this forum: Google [Bot] and 4 guests
