Does anyone have the pdf or even scan of it?I have never seen it? Or have it saved. I have seen links but have not found it and Idk how the archive websites work.
If not anyone err know details were in it?
Team associated ds hex wheels pdf does anyone have it
- Regular Member
- klavy69
- Moderator
- Has thanked: 561 times
- Been thanked: 265 times
Re: Team associated ds hex wheels pdf does anyone have it
Not sure where the original one is at myself but there are tons of threads asking for the same thing. At this point this one has some pretty useful info in it. I'm sure there are more down the page further and back in the older stuff. Otherwise in the quick links at the blue bar above you can search in this section for ds hex wheel conversion and get these other threads that can shed some more light on different ways to convert over to hex wheels.
Look up some of LoboNYC posts if that doesn't help. He does alot with the DS platform and his builds are pretty informative on how to do it different ways.
Good luck.
Good luck.
- LoboNYC
- Has thanked: 814 times
- Been thanked: 344 times
Associated SC10 RS 2wd Front Axle Caster Block 12mm Hexes Rear Carrier Bearings
I've gotten several of these off ebay. Drill bit not included (cant tell you the size. Start small and enlarge a little at a time)
They work on DS cars or GT trucks.
You will need to enlarge the bottom hinge-pin hole on the new c-hub to allow the DS hinge pin to fit.
Do this slowly so it will remain snug with no play.
Also it will move your wheel back about 2mm compared to stock.
- Regular Member
Thanks Lobonyc from what I'm reading I found everyone 1/8" inch bit .I'm gonna measure this week and get a reamer not a drill bit.i bought them already gonna put my nds together with these.
- 717 Views
Last post by Qballll
- 635 Views
Last post by Brandon G
- 30 Replies
- 4253 Views
Last post by HS-YZ250
- 2926 Views
Last post by SteveK
- 1257 Views
Last post by dldiaz
- 34 Replies
- 4109 Views
- 85 Views
Last post by BeastyShout
- 1092 Views
Last post by RCveteran
