12mm hex wheels with shallow off-set?
- dldiaz
- Has thanked: 14 times
- Been thanked: 34 times
I need a set of wheels for a model I am building - just mixing some Tamiya parts,
it is a Tamiya TL-01 chassis with the Ford Racing 4x4 body from a TA-01 kit.
The wheels need to be 12mm hex, with the shallowest possible off-set
(i.e. I need the wheels to stick out away from the body, for clearance).
The overall width is not so important, but I want 2.2" diameter.
The closest thing I know of would be 4x4 buggy front wheels, used at all four corners,
However, I cannot seem to find numbers for the off-set of various 4x4 fronts...
I could even use 2wd buggy fronts with 12mm hex, if the off-set were correct.
Any suggestions are greatly appreciated.
-dldiaz
- Been thanked: 289 times
Re: 12mm hex wheels with shallow off-set?
2.2" narrow crawler wheels are perfect for that, at least for your rears. They're usually between 37 and 42 mm wide and fit standard 2.2" buggy rear tires. The downside is most are beadlocks and therefore heavier, but some of them look beautiful on a buggy. I'm using examples of those wheels on Barney and used them on my buddy's AYK Buffalo that I restored as that car NEEDS negative offset or the tires/wheels rub the chassis plate/shocks.
These also might work, Proline Desperado wheels, which come in 2.2" and look like they have mostly negative offset:
http://www.ebay.ca/itm/200935390778?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Lastly, Hobao Hyper Mini ST wheels might work, they have negative offset but I don't know if it's enough:
http://www.ebay.ca/itm/220834098076?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
The new Schumacher Cougar KR uses shallow 12mm hex wheels all round :
http://www.racing-cars.com/pp/New_Cars_and_Parts/Cougar_KR/U4365.html
http://www.racing-cars.com/sp/category/New_Cars_and_Parts/subcategory/Cougar_KR/templateid/12/searchbox7/1-10_Buggy_Wheels_and_Inserts.html
They're available in white or black. They might work ok.
Paul.
Paul.
- terry.sc
- Has thanked: 6 times
- Been thanked: 82 times
To move the wheels out as far as possible in 2.2", look for wheels designed for Traxxas Stampede/Rustler. They go out pretty far, but most are 2.2" wide as well.
RPM make narrower rock crawler versions of their Clawz and Revolver wheels, the dimensions are on their website http://www.rpmrcproducts.com/products/wheels/Crawler/index.htm
Those are way positive offset, typical of most wheels these days; not negative. Almost no typical dish-style wheels will work because they're all positive offset.CAT3K wrote:The new Schumacher Cougar KR uses shallow 12mm hex wheels all round :
- dldiaz
Thanks for the suggestions, I will be researching a few of these!
As far as the Schumacher wheels - Is it possible that by "shallow 12mm hex" you are referring to the depth of the actual hex adapter (which looks pretty shallow), as opposed to the offset of the wheel itself???
Perhaps I should have started this off looking for "negative" offset wheels,
instead of "shallow"...
Thanks again!
Thanks again!
-dldiaz
- dldiaz
I ended up choosing the RPM Chrome Revolver Rock Crawler wheels in the "wide wheelbase" offset. They work great!
I'll post some pics in a new thread:
"Tamiya TL-01 Rally Truck"
-dldiaz
- 2926 Views
Last post by SteveK
- 1093 Views
Last post by RCveteran
- 3287 Views
Last post by Dual
- 7045 Views
Last post by vinmansbrew
- 1280 Views
- 932 Views
Last post by Trackingz
- 1415 Views
- 99 Views
Last post by mAdMan
Users browsing this forum: Amazon [Bot] and 7 guests
