rebuilding losi xxt and a trans question
- discgolfer72
- Has thanked: 21 times
- Been thanked: 35 times
ok so picked up the lot here
https://www.rc10talk.com/viewtopic.php?f=39&t=43400
after browsing the losi section here i found this vid
https://www.youtube.com/watch?v=w8guwViKDyM
says its for a xxxt
but in the lot of parts I dug up this
looks like the owner may have been trying to convert to a gear diff on this xxt
will it work and what bearings do I need for this trans think I found the top shaft and center gear but no bearings
says its for a xxxt
Reason: fixed youtube link
- matt1ptkn
- Has thanked: 80 times
- Been thanked: 132 times
Re: rebuilding losi xxt and a trans question
The transmission case you have pictured is for the xxx line of vehicles. There were several xxx transmissions over the years, but the XXX-SCT and XXX-DT (desert truck) used the gear diff. The insides of the trans. cases vary widely, but if the gear diff physically fits inside the case, then you should be set. I believe there are bearing kits available on eBay and elsewhere, and parts for the XXX-SCT are still available as well. I run the XXX-SCT gear diff. trans. in my XXXT, but you're going to have some major modifications ahead of you if you plan to put the xxx trans. into the XXT. But it will fit fine in that XXX chassis you have.
Matt
- discgolfer72
thanksmatt1ptkn wrote: ↑Thu Sep 13, 2018 8:04 am The transmission case you have pictured is for the xxx line of vehicles. There were several xxx transmissions over the years, but the XXX-SCT and XXX-DT (desert truck) used the gear diff. The insides of the trans. cases vary widely, but if the gear diff physically fits inside the case, then you should be set. I believe there are bearing kits available on eBay and elsewhere, and parts for the XXX-SCT are still available as well. I run the XXX-SCT gear diff. trans. in my XXXT, but you're going to have some major modifications ahead of you if you plan to put the xxx trans. into the XXT. But it will fit fine in that XXX chassis you have.
after reading a bit it was clear that its not a drop in , and really don't want to rebuild a xxx for a chassis and a few trans parts lol
did get my replacement trans today for the xx
and the seller threw in a big o box of goodies (including a complete extra hydra slipper)
what size screws does the xx use (metric/standard) so I can attach the trans and get her on the road again
ps man I miss my xx buggy I was digging thru my stuff to see if I had a manual and found this pic of my old xx
I really don't remember what happened to it , must have sold it
- discgolfer72
got her back on all fours again
now to dig up some electronics (need a front bulkhead also current one has a big crack )
- matt1ptkn
Looking good! If you are not already aware, www.sabulatech.com has a ton of parts for these, and other vintage Losi vehicles. There is also a nice replacement bulkhead available. He's also a member on here.
Matt
- discgolfer72
purple one showed up todaymatt1ptkn wrote: ↑Mon Sep 17, 2018 8:31 am Looking good! If you are not already aware, www.sabulatech.com has a ton of parts for these, and other vintage Losi vehicles. There is also a nice replacement bulkhead available. He's also a member on here.
have a few brushed esc's showing up tomorrow
and hopefully my body shows up from Canada fast
- 3495 Views
Last post by Lavigna
- 1685 Views
Last post by wyldbill
- 36 Replies
- 6174 Views
Last post by shoman24v
- 571 Views
Last post by toykilla
- 1769 Views
Last post by aradaiel
- 409 Views
Last post by mrlexan
- 2136 Views
Last post by hkp
- 1172 Views
Last post by THUNDERSTRIKE1
Users browsing this forum: pedro and 21 guests
