Losi XXT-CR
- mrlexan
- Been thanked: 10 times
Losi XXT-CR
Anyone have any info on the XXT CR? Manual? Differences between the XXT and the XXT CR? Any help would be appreciated. Thanks in advance.
jay
jay
www.gojammedia.com
www.gojammedia.com
- mrlexan
Re: Losi XXT-CR
Not to answer my own thread, it is more of a question, but Losi used to have all the older kit manuals on their site. Since the change/update to the site, I can't find them. If anyone can, I would appreciate it. Thanks again.
www.gojammedia.com
www.gojammedia.com
- JK Racing
- Has thanked: 103 times
- Been thanked: 200 times
Re: Losi XXT-CR
The CR had shorter arms, a wider pivot block (which was now a seperate piece from the pivot plate) and different hubs. The Graphite Plus was the CR with all the hop-up parts, plus the dual-disk slipper instead of the Hydra-Drive.
quoted from another forum, post by Aaron Waldron
Re: Losi XXT-CR
relating to the buggy: *should have read J's question properly*
The CR also had a different shell (I did know the name). two hole front hub carriers, solid battery strap rather than velcro, spoked wheels, different front shock tower (although that may have been the kinwald) and some other detail changes.
turned my XX into a CR and did have a both parts sheets once..
- mrlexan
Re: Losi XXT-CR
So does that mean that the XX-CR and XXT-CR where esstentially the same thing with a differences in the body, wheels/tires, arms and towers?
Still hoping for a link to Losi's old manuals.
www.gojammedia.com
www.gojammedia.com
- Minicooper 35
Re: Losi XXT-CR
I only could do with the setup sheet. http://losi.com/RaceCenter/DiscontinuedSetups.aspx#doubleXTCR
Did you try the Horizon Hobby homepge?
"The things you own, they end up owning you."
- mrlexan
Re: Losi XXT-CR
Yeah, I found the setup sheet. Thanks, I will try horizon.
www.gojammedia.com
www.gojammedia.com
- Brandon G
Re: Losi XXT-CR
Here's what I know:
the cr had:
A different body,
Graphite arms, shock towers, and chassis compared to plastic,
Removable rear pivot block,
Rear arms have a separate molded riser that raises the bottom shock mount location,
Hydra drive equipped.
http://www.rcchopshop.com/losi/losiinfo.html
they have the parts lists.....
the cr had:
A different body,
- mrlexan
Re: Losi XXT-CR
www.gojammedia.com
www.gojammedia.com
Re: Losi XXT-CR
Did the XXT-CR have graphite or was that the XXT-CR G+? (I have a decal sheet for that truck NIP if anyone is after one)bngiles wrote:Here's what I know:
the cr had:
A different body,
- mrlexan
Re: Losi XXT-CR
Which decal set Tom? I would be interested. Let me know. Thank you sir.
www.gojammedia.com
www.gojammedia.com
- JK Racing
Re: Losi XXT-CR
There was a graphite plus version of the truck...I believe the decals said "Graphite Plus"
Re: Losi XXT-CR
Indeed those are them.. all neon and nineties-like. I'll take a picture and send it for you Jay. Drop me your email again by PM
- 36 Replies
- 6174 Views
Last post by shoman24v
- 409 Views
Last post by mrlexan
- 1172 Views
Last post by THUNDERSTRIKE1
- 1798 Views
Last post by urpaldan
- 2326 Views
Last post by spydur23
- 1030 Views
Last post by geeforce59
- 1860 Views
Last post by FasterLouder
- 1906 Views
Last post by Diamond Dave
Users browsing this forum: Google Adsense [Bot] and 11 guests
