Dhawk and racing
- abailey21
Dhawk and racing
Hey guys
So I have an absolute F-ton of RC10's I've been collecting over the past few years. With my job and the travel I haven't had any time to race let alone the couple days a year I get too wrench. Even though a basher worlds car out here in west Africa would be about the highest level of awesome right now.
So I have like 8 projects running, all of them started as rere worlds cars, Most are just updating to RC Carbon shock towers but the one racer I want to finish and actually hit the track with is a rere with most all the JC aftermarket stuff. I have the bellcranks, nose tubes, motor plate. I have a Reedy 17.5, Blackbox 800 all the crap I need to get up and running.
I've thought of doing a Dhawk build and I've read all about the up's and down's of their parts, fit and what not so I know what I'd be getting into but I'm considering the rear mounts for my runner. I know this is a weak spot and I know by installing them I'm setting myself up for broken rear arms and rear hub carriers instead of the rear mounts.
But is anyone racing with these or am I gonna be the only one?
I know I know I wanna post pics of the ever expanding fleet but my cars are 10,000 miles away, yes I'm as sad as you are
- shodog
- Has thanked: 3 times
- Been thanked: 86 times
Re: Dhawk and racing
On my Classic I used the Dhawk rear mounts with RPM arms. I found that I needed to grind off a portion of the arm to get it to fit because the mounts are slightly bigger than stock.
the Dhawk arms and mounts work together perfectly
- abailey21
right on, thanks man
Still not sure I wanna go that route, I may wait but a full set of Dhawk stuff and build an all green anodized white powder coat tub still. Just not sure
- yellowdatsun
Aluminum is very heavy compared to plastic, and also doesn't bend in a crash. Therefore the car will be heavy, and parts will break. Trust me, I've tried it. I have RPM arms and kept breaking inner hinge blocks, so I went to aluminum, and now it just shears bolts off. You have to leave a few flexible plastic parts on, otherwise when you crash you'll have a bumch of sheared or permanently bent parts. The weight won't help you either. I do use a few aluminum parts, but not a lot, and definitely not in parts like arms, or big parts that weigh a ton.
- abailey21
Oh I know the normal downsides of using aluminum parts thats why I was only gonna get the rear arm mounts cause that just seems to be the one weak area
Guess I could improve my driving???????
- yellowdatsun
Rear arm mounts are one of the areas where aluminum is a really good idea. I have them on mine. Go tired of breaking arm mounts. I have the front too.
- RC10th
- Has thanked: 40 times
- Been thanked: 1017 times
I think the arm mounts will be fine for racing. Make sure you replace the re-re arm mount screws with original ones or others otherwise your setting yourself up for broken screws in the mounts.
- Has thanked: 822 times
- Been thanked: 2418 times
Yeah the stock green hardware on the rere are especially delicate. Team KNK makes a nice stainless steel screw set for about $20 that is very nice for runners
Factory Works website
- yellowdatsun
I ended up putting stainless screws in place of the green screws for the trailing arm hinge mounts.
Once I had the aluminum trailing mounts installed, I sheared a couple green bolts, got fed up with that, and got the stainless bolts. Haven't broken one since.
yellowdatsun wrote:Aluminum is very heavy compared to plastic, and also doesn't bend in a crash. Therefore the car will be heavy, and parts will break. Trust me, I've tried it. I have RPM arms and kept breaking inner hinge blocks, so I went to aluminum, and now it just shears bolts off. You have to leave a few flexible plastic parts on, otherwise when you crash you'll have a bumch of sheared or permanently bent parts. The weight won't help you either. I do use a few aluminum parts, but not a lot, and definitely not in parts like arms, or big parts that weigh a ton.
Very well stated.
My first time building a re-re World's got a bit out of control and turned into a shelf queen because of Dhawk parts . The fit and machining are amazing and they do look great. The Dhawk gearbox cases are very nice and I probably going to convert my bashers to them at some point. That is about all I would put on something that I know is going to get run time.
Not a racer and I only bash, but what yellowdatsun said is very sound advice for any type of runner.
I hear ya guys, this is how my Dhawk ended up. It's hard to stop!
- abailey21
GoMachV wrote:Yeah the stock green hardware on the rere are especially delicate. Team KNK makes a nice stainless steel screw set for about $20 that is very nice for runners
Yeah I have KNK screws on all my builds...speaking of that I need to pick up a couple more sets
- Regular Member
- 1356 Views
Last post by shodog
- 2209 Views
Last post by AustinZ
- 2961 Views
Last post by killswitch
- 1150 Views
Last post by Sixtysixdeuce
- 988 Views
Last post by Skeetie96
- 639 Views
Last post by XLR8
- 628 Views
Last post by shodog
- 3124 Views
Last post by blubblood
Users browsing this forum: Amazon [Bot], Google Adsense [Bot] and 34 guests
