Looking at a Dhawk build....maybe
- abailey21
Ok, so I've searched and searched on here, found that there used to be a thread about the Dhawk stuff on the ebay threads but couldn't find it.
Looking for info from people who have used the Dhawk parts, fitment, quality, color matching to the gold and or blue?
If I do a build I'm looking at a black chassis and blue parts, more for a shelfer but I'd probably throw bearings at it.
I did read in a thread here that bearing fitment was pretty tight but thats about all I've found.
Maybe a white powdercoat chassis with the blue, not sure.
I'm just looking for feedback from those that have used his stuff?
- shodog
- Has thanked: 3 times
- Been thanked: 86 times
Re: Looking at a Dhawk build....maybe
I have a silver set of the parts you are thinking about getting in blue. They are not perfect but they are a good value for the money. The rear hub carriers are for non flanged bearings. I found that my flanged bearings with 1/4 axles wouldn't work. The steering bell cranks use metric hardware in place of an 8/32 screw.
- abailey21
thanks man, is everything else standard hardware except the steering?
- JK Racing
- Has thanked: 103 times
- Been thanked: 200 times
Everytime I see those parts I drool...FYI, Atomik-RC.com has them here stateside. Not sure what they have in stock or in what colors, but I know they are on the site.
- abailey21
All they have is the gold, but it's $80 cheaper than ebay!
Black tub gold parts could be a project?????
- aeiou
That's what I ended up doing with my black re-re chassis set. I personally really like the black and gold look. Just as an FYI, I don't think atomikrc carries the kit with the a-arms, but I'm not 100% sure. Also, I purchased a silver set from dhawk a couple of months ago and they did accept a lower offer. Just something to keep in mind when you are ready to pull the trigger. As shodog mentioned, these parts aren't perfect, but I was very pleased with the quality given the price.abailey21 wrote:Black tub gold parts could be a project?????
- shodog
Its the aluminum parts kit for the Classic that doesn't come with the arms. I used this on my classic and found that I had to modify my RPM arms to fit the rear arm mount which is slightly larger. If your buying the dhawk kit with arms , this is not an issue.abailey21 wrote:All they have is the gold, but it's $80 cheaper than ebay!
Also on the tranny I had to re-mill the hole on the out drive to run the extra external support bearing.
- 3125 Views
Last post by blubblood
- 20 Replies
- 5062 Views
Last post by Zac_F71
- 2209 Views
Last post by AustinZ
- 988 Views
Last post by Skeetie96
- 1150 Views
Last post by Sixtysixdeuce
- 639 Views
Last post by XLR8
- 2961 Views
Last post by killswitch
- 628 Views
Last post by shodog
Users browsing this forum: Google Adsense [Bot], Tbot [Bot] and 41 guests
