Clear frame mid motor chassis build. WOWSER!
- Been thanked: 5 times
While working on the Advanced racing products reproduction project I decided to design and build a clear frame for this mid motor set up. It still needs a little design work on the rear end. I need to add support braces to stiffen up the rear end. I pretty much had to build the car so I can work out a brace design. Hope you enjoy!
- limestang
- Has thanked: 21 times
- Been thanked: 160 times
Re: Clear frame mid motor chassis build. WOWSER!
Excellent work as usual!
The lexan chassis gives a new dimension to Stealth:)
- Attachments
- Invisible Car.jpg (9.31 KiB) Viewed 1843 times
- slotcarrod
- Been thanked: 41 times
chassis!
Rod Littau
Thanks everyone! Designing machining and building this buggy chassis and wing took me two days. Ibe got a little work left to do. Still working on the rear brace to strengthen the rear end to eliminate flex.
That is sweet, don't forget to engineer some ghost lighting into it. I bet some strategically placed LEDs would be wicked. Its definitely awesome.
I've got led lighting in the works already! Soon !!
- flipwils11
- Been thanked: 15 times
Just when I think I've seen most of the innovative rc10 builds.... THIS! Fantastic!
Thanks a lot! I was working on the mid motor advanced racing products reproduction parts when I decided I should build my own chassis to go wit it. And two days later I had this sweet little jem built.
- flipwils11
I would be interested in a kit to do my own build if you decide to sell any.
Great! PM me if you'd like. I believe I have a calculated price for this kit. I am BST approved FYI. And the kit would include the rear chassis support once I finish the design.
- mk-Zero
- Business Member
- Has thanked: 4 times
- Been thanked: 19 times
- 707 Views
Last post by tazz888
- 254 Views
Last post by juicedcoupe
- 78 Replies
- 20596 Views
Last post by nbrophy
- 33 Replies
- 4112 Views
Last post by y2kgtp
- 32 Replies
- 3058 Views
Last post by lowrydesign
- 1016 Views
Last post by JK Racing
- 1694 Views
Last post by THEYTOOKMYTHUMB
- 3314 Views
Last post by Booa
Users browsing this forum: Google Adsense [Bot] and 44 guests
