Motor Spacer
- DMAT
Motor Spacer
So I need to pull the motor I have slightly back off the motor plate so the shaft doesnt hit the gear cover. My normal thought would be to just use washers but I dont know if that will end badly or not.
Any suggestions or just go with it?
- dldiaz
- Has thanked: 14 times
- Been thanked: 34 times
Re: Motor Spacer
There are "heatsinks" that fit between the motor and motor plate.
(I can't find a picture of one right now)
It is a round aluminum piece with veins milled into it, the idea being to allow airflow through the aluminum to aid in cooling.
I don't know if these are still available new, but I have seen them on eBay -
I think this would be perfect for your application.
-dldiaz
- integra22t
Re: Motor Spacer
if you have a old motor plate just cut it down to the size of the motor and install between the two .. i wouldnt do washers ... unless you find a big washer that the motors nose would pass throu and drill 2 holes for the bolts to pass throu
- DMAT
Re: Motor Spacer
i thought those heatsinks were always for the outside but if it works, im in.
now to see if i can find one that will work on my velineon. gonna sacrifice my oldest one to the deanodizing process and cross my fingers i dont ruin it.
edit, another strc part gets added to my build. Really like those guys parts, they just seem to have made exactly what I need before I even need it
- THEYTOOKMYTHUMB
- Has thanked: 2122 times
- Been thanked: 1346 times
Re: Motor Spacer
The heatsink mentioned is probably the best idea and I think would work on either side with it's added surface area to more quickly dissipate the heat. I think washers would even be fine as long as they were a snug fit to the motor screws and the screws were nice and tight in the motor. If you found something less rigged up, all the better though.
- Incredible_Serious
- Has thanked: 1405 times
- Been thanked: 861 times
Re: Motor Spacer
Either of these would suit....
Have them rolling around in my junk box....
Re: Motor Spacer
Trinity use to make the heat sink motor spacer. I have one on my worlds car from back in the day. Very rarely see them on e-bay.
NEW: SC10 4x4 FT, SC10 FT, (2)T4.1 FT, B4.1 World
OLD RC10's: (4)Worlds, Graphite Team Car, (2)RPM Ultra's, Tekin, B2 Team Car, B3, (3)Champ Editions, Team Car, (2)RC10T Team Truck
Tamiya: Hornet, Fox
Bolink: Invader
Losi: (2)XX, Junior 2, JRX Pro SE
Tamiya: Hornet, Fox
Bolink: Invader
- 1058 Views
Last post by y2kgtp
- 1226 Views
- 1393 Views
Last post by radioactivity
- 1005 Views
Last post by isobarik
- 504 Views
Last post by juicedcoupe
- 603 Views
Last post by 66intheSky
- 1444 Views
Last post by JosephS
- 113 Views
Last post by Rouki
Users browsing this forum: Bing [Bot] and 8 guests
