jrx2 axle spacer
jrx2 axle spacer
anybody have a pic and measurements for the spacer between the rear hub bearing and the drive pin? mine are missing and i might make a few on my lathe, thanks.
Re: jrx2 axle spacer
never mind, i found them online, you can still get them. I thought they might be hard to get.
- highwayracer
There are 2 versions depending on the type of rear hub you're using. If you're using the the hub for the 5 link, then you need the thick single spacer (1 on each axle). If you're using the smaller hub, then you need the 2 thin spacers (2 on each axle).
Regards,
highwayracer
Regards,
highwayracer
- Been thanked: 12 times
I've always used the same spacer on all rear hub types, did not know there was any other.
http://www.horizonhobby.com/Products/Default.aspx?ProdID=LOSA3016
$2 for 2
I made some out of aluminum tubing from the lhs. Not as pretty as the factory ones, but for the same $2 I got enough tubing to make a ton of these
$2 for 2
I think I will find some tubing as well...aconsola wrote:http://www.horizonhobby.com/Products/Default.aspx?ProdID=LOSA3016
$2 for 2
- 113 Views
Last post by Rouki
- 848 Views
Last post by JosephS
- 2204 Views
Last post by mvelarde890
- 1057 Views
Last post by Chris00gt
- 1226 Views
- 1393 Views
Last post by radioactivity
- 1005 Views
Last post by isobarik
- 504 Views
Last post by juicedcoupe
Users browsing this forum: Amazon [Bot], Facebook [Bot], Google Adsense [Bot] and 11 guests
