R10T/T2 12mm hex
- Trackingz
R10T/T2 12mm hex
Hello i was wondering if anyone has done a 12mm hex conversion on a RC10t/t2
Formerly known as veeza
- bully
- Been thanked: 6 times
Re: R10T/T2 12mm hex
Dunno if it's been done or not but quite simple. The rear needs 3/16 axles then the hex of choice. The front needs SC10/T4.2 caster blocks and hex steering block an axles then the hex itself.. If you check parts lists or manuals on Team Associated website you can find the part numbers.. Many guys have done it with the DS to be able to use HPI vintage style wheels, a quick search through the on road section might give you an idea of whats involved..
- Trackingz
thank you bully great help, ive just picked up a R10ds and some retro wheels would be cool, im going to check out hpi now have a look at the wheel and the associated page for the part numbers
- Has thanked: 10 times
- Been thanked: 447 times
depending on offset, and if you strictly care about ROAR regulations, you may be able to just run the hex adapters on the 1/4" axles like so:
http://www.ebay.com/itm/associated-RC10-hex-adapter-for-RC10-1-4-axles-/331568163977?hash=item4d3300ac89
for the front run the B4.x type hex axles as mentioned.
- 7046 Views
Last post by vinmansbrew
- 933 Views
Last post by Trackingz
- 100 Views
Last post by mAdMan
- 1415 Views
- 2928 Views
Last post by SteveK
- 895 Views
Last post by Lonestar
- 3162 Views
Last post by juicedcoupe
- 1260 Views
Last post by dldiaz
