RC10T4.1 Brushless Upgrade Options
Post Reply
Sharky
Post by Sharky »
I have a stock brushless setup for my truck and am looking to upgrade the motor to something with a little more power. Without checking the spec sheet, it seems to me the current motor is 3300kv unit. How far can you safely raise the power before needing to upgrade to metal bits for the drivetrain?
Sorry if posted in the wrong section, if so, mods can you please move?
Thanks for any info.
Sharky
kaiser
Re: RC10T4.1 Brushless Upgrade Options
Post by kaiser »
first you'll need a sensorless motor. most racing brushless motors are sensored, but the rtr stuff is not.
the drivetrain can handle a pretty powerfull set up, but i wouldn't go to crazy.
something in the 4000-5000kv range will be where you want to look. anything higher then that is kinda too fast for a 2wd truck.
i know hobbywing has a pretty extensive selection of sensorless motors.
you will also have to adjust your gearing for the hotter motor.
Sharky
Post by Sharky »
kaiser wrote:first you'll need a sensorless motor. most racing brushless motors are sensored, but the rtr stuff is not.
Thanks Kaiser, just the kind of info I needed.
:D
gtv1
Has thanked: 5 times
Been thanked: 17 times
Post by gtv1 »
I have just upgraded my B4 to a hobbywing Xr10 juststock esc and 13.5T motor. so far it seems really good for the money.
Post Reply
  • Can a stock RC10T4 handle brushless power?
    by sbsyncro » » in Modern Electronics
    Last post by Chris00gt
  • brushless upgrade
    by gtv1 » » in Modern Electronics
    Last post by gtv1
  • Old 6-gear upgrade for brushless
    by strangersinspace » » in RC10 Buggy Forum
    Last post by Russ Winn
  • Putting the Turbo in my Turbo Raider (Brushless Upgrade!)
    by Snaab9-2 » » in Kyosho Forum
    Last post by Snaab9-2
  • 13.5 turn or 17.5 turn brushless for JRX2 upgrade?
    by License2iLL » » in Losi Forum
    Last post by JK Racing
  • Question: Klein rear arms, rear hub options and CVD options
    by mdutcher » » in Temple's RC10 Tech Forum
    Last post by mdutcher
  • RC10t4.1
    by Dave145 » » in 21st Century Modern
    Last post by Dave145
  • Rc10t4 body
    by j.d.roost » » in 21st Century Modern
    Last post by j.d.roost
