Hi folks, sorry if this is a noob question.
I have a B4 which I am now looking to upgrade to brushless. I used to race for about 15yrs but got out just when brushless was coming out, so I have very little knowledge of brushless setup.
Now I think I am going for a hobbywing esc and 13.5T motor, but my question is what size pinon should I run? is there a final ratio I should be looking for and what do people recommend?
Many thanks for any help you can give.
brushless upgrade
- juicedcoupe
- Has thanked: 231 times
- Been thanked: 1747 times
Re: brushless upgrade
This should get you close. It's from the B5 manual but both have the same gear ratio transmission.
- gtv1
- Has thanked: 5 times
- Been thanked: 17 times
Thank you for that. helped alotjuicedcoupe wrote: ↑Sun Mar 17, 2024 5:11 pm This should get you close. It's from the B5 manual but both have the same gear ratio transmission.
- Has thanked: 1032 times
- Been thanked: 488 times
I see you have your answer, but for others just starting with brushless: the motor manual will have a target FDR for your vehicle type (2WD, 4WD, Short course, etc).
Spur gear teeth divided by pinion teeth times transmission ratio gets you your final drive.
For example, my motor manual called for 8:1 for a 2WD buggy. The Top Cat Pro transmission has 2.066 internal ratio. 89 tooth spur / 23 tooth pinion x 2.066 transmission ratio gives FDR of 7.99.
Then just check motor temp after a good run. Excessive heat will shorten the motor life.
- 3372 Views
Last post by Russ Winn
- 659 Views
Last post by gtv1
- 630 Views
Last post by Snaab9-2
- 2140 Views
Last post by JK Racing
- 525 Views
Last post by LTO_Dave
- 1729 Views
Last post by tjmoes
- 821 Views
Last post by SnoopMaxx
- 32 Replies
- 4386 Views
Last post by stoggie388
Users browsing this forum: Facebook [Bot] and 3 guests
