6 gear transmission upgrade?
I'm pretty sure I've seen this posted somewhere on here before, but how do you put an RC10B4 slipper clutch on a 6 gear transmission? I know I need the B4 top shaft and the V2(?) clutch plates along with the clutch discs and gear.
Is that it or do I need something more? I'm finally tired of my 6 gear transmission crappy clutch arrangement.
Re: 6 gear transmission upgrade?
Not possible unless you have a stealth.
― Confucius
― Confucius
- Has thanked: 822 times
- Been thanked: 2418 times
Your confusing it with the conversion of a stealth to b4 slipper. As said above, not possible. On a 6 gear that is your diff, not slipper
Factory Works website
Okay thanks I forgot if it was possible to put the B4 clutch plates on the top shaft of the 6 gear transmission.
that would be IM-possible...Just get a stealth Tranny then go for the B4 Mod... much easier and has more parts available.
― Confucius
― Confucius
just get it from here, if you access on to BST thread the you can post in the Wanted section.
― Confucius
― Confucius
- 26 Replies
- 12404 Views
Last post by stingerrray
- 5212 Views
Last post by Phin
- 2386 Views
Last post by rctenracer
- 272 Views
Last post by Braydun
- 3372 Views
Last post by Russ Winn
- 1526 Views
Last post by badhoopty
- 463 Views
Last post by Westcoast10z
- 866 Views
Last post by teman
Users browsing this forum: Amazon [Bot] and 27 guests
