Parts to Identify 2
Parts to Identify 2
A few more parts to identify:
Is the A+L steering for the Ultima, Optima, or Optima Mid?
Also, the gear and belt were on an Optima parts car, but what type is and was it really for the Optima?
Thanks!
RG
Thanks!
RG
- Been thanked: 288 times
Re: Parts to Identify 2
The upper left gear looks to be the Turbo Optima version of the center gear with the torque limiter spring. The original Optima/Javelin gear was a solid shaft.
- losiXXXman
- Been thanked: 5 times
That's a Gear diff for ultima. And the outer gear as well. THe c'cranks are A&L, I think thay're the Ultima set, but could be Jrx2/T or RC10. Me LIKEY the hyperdrive pulleys as well - I'm assuming they are for an Ultima too.
- Has thanked: 7 times
- Been thanked: 41 times
Optima/Ultima if anything. The only parts from that lot that fit the Mid are the bellcranks.
- Mr. ED
- Has thanked: 58 times
- Been thanked: 56 times
The belt drive parts are for the ultima also they replace the spur and second gear on the top shaft.
I've never seen these parts beside from the ads in RCCA.
The diff is ultima, not optima or mid: there's no chain or belt pulley on it.
- 768 Views
Last post by Mr. ED
- 1346 Views
Last post by unclemikey1978
- 1511 Views
Last post by rangerg
- 653 Views
Last post by BattleTrak
- 30 Replies
- 8063 Views
Last post by j.costick
- 1454 Views
Last post by airdreams1
- 1903 Views
- 20 Replies
- 4451 Views
Last post by klavy69
