I thought this was pretty cool!
http://vimeo.com/21324013
New from Italian company Laurus is the EC1 Colibri, a unit for bench testing engines. Suitable for a wide range of engine size past 3.5cc, it puts the engine under load during running to simulate on track usage and even sports a built in brake. Featuring a built in starter that gets the engine powered through a built in lever, the throttle of the engine is controlled by a LAN powered device for safe operation. For cooling, once started the motor is encased in a fan cooled casing for a controlled testing environment. Connected to a computer by USB, the software that comes with the device allows you to measure a wide range of parameters from the engine including rpm, acceleration, running and peak temperatures and it allows you to compare the results with other engines. Not a device for everyone, but if you are serious about tuning engines, this is worth looking at.
Engine dyno for R/C!!
- lowrydesign
- Has thanked: 11 times
- Been thanked: 17 times
- 852 Views
- 1906 Views
Last post by marty slater
- 6124 Views
Last post by RC10superfan
- 1047 Views
Last post by juicedcoupe
- 971 Views
Last post by Lastplace
- 1674 Views
Last post by tamiyadan
- 1233 Views
Last post by dinglem
- 2730 Views
Users browsing this forum: Facebook [Bot] and 40 guests
