i wanted to see if it was at all possible to use the gt2 slipper assembly and brake rotor on my gt with a b4 topshaft, and low n behold it all works.. the gear lines up as well as the brake rotor with the shoes
the only mod that had to be made was to ream out the output hole on the trans so the slipper/brake hub could meet up to the bearing inside the trans with the help of an additional top shaft spacer "same spacer used on the inside of the gt on the top shaft"
now i can use the gt2 spur gears and the losi Kevlar gears
this was all done so i could use the 54-56 gears on my gt that i use in the sand dunes, i will be posting some pics of the build soon.
rc10gt slipper upgrade
- lowrydesign
- Has thanked: 11 times
- Been thanked: 17 times
- 822 Views
Last post by SnoopMaxx
- 712 Views
Last post by KidAgain
- 36 Replies
- 9416 Views
Last post by NomadRacer
- 135 Views
Last post by JRxJoe
- 861 Views
Last post by JosephS
- 1831 Views
Last post by Sixtysixdeuce
- 926 Views
Last post by Joe6Pack74
- 1341 Views
