** What's Old is New Tech Thread **
- Has thanked: 30 times
Re: ** What's Old is New Tech Thread **
I like to know what the benefit of the dynotech/klein arms is? But these runner/builds are really sweet, GREAT job by all of the guys who have done this, man I cant figure out which is nicer Good question about the buggy and truck nose plate and tubes, I cant figure that one out.
Lifes to short not to play with toys.
- soniccj5
Provides a wider stance which helps with handling.moto-steve wrote:I like to know what the benefit of the dynotech/klein arms is?
- hairymuffin
are there any current diff rings to fit the original stealth diff? bout to do a rebuild and im sure it could use new rings
- Has thanked: 822 times
- Been thanked: 2418 times
TC3 diff rings are the same as the stealth and the Associated TC3 diff rebuild kit both work great
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXPA07
Factory Works website
- hairymuffin
- soniccj5
I was just going to look this up. Thanks for saving me some time. Might build a spare stealth.gomachv wrote:TC3 diff rings are the same as the stealth and the Associated TC3 diff rebuild kit both work great
- Johnboy72
Anyone have a part number for the RPM world's arms? The Dynotech look fine but I like the look of the RPM parts. Really want to start on one of these WOIN projects!
- Has thanked: 28 times
- Been thanked: 957 times
if you're looking for "new" rpm worlds arms, you definitely don't want to get started on a build anytime soon.
- Orange
LOL!scr8p wrote:if you're looking for "new" rpm worlds arms, you definitely don't want to get started on a build anytime soon.
What he means is, they are hard to find and when you see a set on ebay, expect to pay a premium for them... I would start a wanted thread in the BST section asking for them... There may be someone willing to part with some decent used arms for a semi reasonable price. Of course that depends on what your idea of reasonable is, everyone is different.
the rear arms are #8017. not sure on the fronts, #8003 i think.
Or Jakes arms....wonder of we will see them again soon?Johnboy72 wrote:OK so that is why everyone uses the dynotech arms.
In the last month I have seen a set of fronts sell for $25.00
http://www.ebay.com/itm/190998295027?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_63wt_1200
and a set of rears with carriers and mounts sell for $60.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=141108515456#ht_283wt_1200
You can still find them but you really have to keep an eye open, at least one of those auctions was from a fellow member, probably both.
Rear mounts are pretty easy to find:
http://www.ebay.com/itm/Vintage-RPM-Rc10-Worlds-Rear-Arm-Mounts-Red-/281230797583?pt=Radio_Control_Parts_Accessories&hash=item417aa96b0f#ht_63wt_1133
I also have a few extra pairs of rear mounts and an original RPM fiberglass front shock tower but I would recommend Aaron's thicker shock towers instead
I found my RPM parts as a complete car for around $125. If you can find a complete car like that you would be dollars ahead as it's usually cheaper.
With that said, the dynotech parts are readily available, cheaper and there's no fear of breaking a hard to find part if it's a runner. Of course, RPM parts are usually pretty tough to break anyways... I run my RPM worlds car and I love it from what little I have ran it so far.
You're close enough that if we end up running into each other that you're more than welcome to take it for a spin. I'm in the process of building a Klein armed OIN build and I'll be able to compare the two sometime in the Feb/March time frame. I have the arms and RPM 70727 rear hubs, the rest should be easy to find!
Good luck
Good luck
- Johnboy72
Are these Worlds Arms? Or just standard wide arm length? Can you even tell by the photos? The RPM arms I have only have one shock hole and are the same length as my stock wide arms. I'm about to pick this up in about a week in a lot and bonus if it'll work for the WOIN build.
Edit: The arms I have are Andy's arms with one hole and same length as the wide arms.
- 50 Replies
- 6115 Views
Last post by Group B
- 822 Views
Last post by Shadow
- 596 Views
Last post by myfordcnc
- 684 Views
Last post by Halgar
- 4668 Views
Last post by Lonestar
- 1127 Views
- 1977 Views
Last post by mytimac
- 434 Views
Last post by Brandon G
