CW Dominator tech question....
- Brandon G
Does the hub for the Dominator have the same screw spacing as a RC10L rear wheel?
I hope so...
I hope so...
Re: CW Dominator tech question....
I believe so.
Last year, I purchased a dominator and was given a NIP set of RC-10L rims. I never tried them out but assume that was the reason why they were in the box.
- Has thanked: 28 times
- Been thanked: 957 times
they're the same as yokomo hubs. pan car rims should not fit. the scew holes are farther apart.
- Eau Rouge
They are not the same. Jason is right, they are Yokomo hubs. Any Yok wheel will work perfectly, but not an on-road wheel.
- LTO_Dave
- Has thanked: 46 times
- Been thanked: 225 times
I actually asked this question on DODC because I wanted to mount the Dominator Cyclone wheels to the pancar adapters on my Slingshot.
Here's the thread: http://www.dirtoval.com/forums/showthread.php?t=37401
I found a pic of a Dom with the BBS pancar wheels mounted, but never received a response.
- Eau Rouge
Someone had to custom make those adapters to use pan wheels on the Dom/Yok axles. I don't know why you would want to, those tires on a Dom would give you an unusable and non-adjustable ride height, and there are plenty of foam tires available for Dominators.
The inside mounting diameter of a Dominator wheel is a LOT smaller than the on road wheel, and the bolt holes are not the same. Those adapters are not the same.
- Brandon G
I have a few 10L rear wheels, gold aluminum BBS style. I can machine them to whatever width I would need to fit the OE track width and tire width of the Dominator . Seems that the adapters on the Dom uses the yoke measurements, so at this point I will either need to scrap the idea, or just machine adapters to fit the axles to 10L rear wheels.
I guess I will just fire up the lathe and get to work.
After the dominator arrives at my door, that is.
- 1265 Views
- 684 Views
Last post by Halgar
- 853 Views
Last post by Erich Reichert
- 1232 Views
Last post by germanrc10gt
- 290 Views
Last post by Dirtdiver
- 795 Views
- 898 Views
- 2685 Views
