Wondering about just the CVD bones, I'm guessing the B4's are longer but does anyone know what the actual lengths are? I *think* I used B2 CVD bones on the rear of my car with the MIP RC10 CVD kit so I could use the Klein arms or maybe I used B4,...
Ok, so then what I must have done (can't remember now, lol) is use the B4 CVD bones with the RC10 stock axles.
Hello folks. So I was reading a ton of posts in regards to worlds front ends, switching to 2.2 wheels, etc...With that said, I've decided to do both.
A little background:
I have a graphite chassis which I thought was going to be my pride and joy...
The car will feel very free with a short wheelbase and should have better corner entry, but less exit speed be a little slower in the rythm sections or rollers and will jump with a higher altitude than a standard car. But that is based off of no...
I would like to convert my gold tub to truck specs.am i relegated to getting stuff off ebay or can i use the parts from the newer stuff at tower hobbies.can someone give me a break down on what i need?thanks
Yep, and it's actually probably a prime time to pick up a 10T before what has happened to the RC10's value happens to the 10T. It'll happen sooner or later.
I have a couple Futaba Magnum Jrs. I really like them. They just have the right feel to them in my opinion. Is it possible to convert these to 2.4ghz?
Or convert any of the older radios for that matter?
post your build thread.. sure guys on here will follow..
I have read threads here but am stll not sure what to do? I have an RC10 B3 that I want to convert to brushless. I will be running it for fun on the street. I guess from what I have read that I need a sensored motor, and do I need an ESC...
So I’ve read all I can find on the topic of converting a Futaba Magnum PCM 1024 FP-T3PB to 2.4. Unfortunately the threads that I have found are all a little aged and none of the modules discussed appear to be available.
Is there a drop in module...
If you can still find one these work great.
I included the Banggood link because it's available but that's double the price of the one I got from HobbyKing about 7 years ago.
I still used this radio a few years ago for some indoor racing....
I have a XX sitting quietly on the shelf. It hasn't been run in about 15 years although it is perfectly mechanically sound. Although I could install electronics in it and go racing again I find myself having much more fun with my RC10 and JRX2 cars...
The SCT races are probably my favorite to just watch when at the track. Those things are all over the place. It's fun just to watch them lose it mid air off of a jump or in the middle of a corner. You'd swear it was a bunch of NASCAR drivers at the...
So I ran into an RC Screwz kit for the B4.2 in metric sizes. I’m under the impression that the RC10B series didn’t make the switch to metric until the B5, and I vaguely remember using imperial drivers on my FT B4.2 (don’t remember for sure).
