converting to 3/16 cvd's
- Regular Member
Hello, I looked for this info and had no luck.I am sure it is here somewhere or maybe I missed it.Sorry,I am sure this has been asked numerous amounts of time. I am looking to convert my 10t to 3/16 cvd's.What all is needed to do the conversion?Also what is a good rim/tire combo to go with once this has been completed.Thanks for any help.
Re: converting to 3/16 cvd's
You need a 3/16 CVD kit, and 3/16 X 5/8 bearings and T2/T3/T4 wheels. Tire combo's vary, but the proline edge and the proline bowtie rears are cheap, versatile and damn plentiful on flea bay-
- Regular Member
Thanks for the info.I just ordered a new set of 3/16 mip cvd's and a set of 4 rims with grp tires.I will try this setup and see how it does.Thanks again
Glad i saw this was about to make myself look stupid by asking the same question!
Make sure you either heat shrink or get the RC10GT pin retainer clips (sold separate) for the bells...those pins come out awfully easy and destroy arms when they do. Not sure why they don't come with the kit.
HH TQ10
I knew about the heat shrink but no the pin retainer clips...do you have a part number? I searched Tower and Associated's pages but couldn't find one.floodx wrote:Make sure you either heat shrink or get the RC10GT pin retainer clips (sold separate) for the bells...those pins come out awfully easy and destroy arms when they do. Not sure why they don't come with the kit.
The closest I could find was the quick change pin retainer:
http://www3.towerhobbies.com/cgi-bin/wti0095p?FVPROFIL=++&FVSEARCH=7996
SC10 -- FT B4.1
those are the ones they fit the associated 3/16" b44 rear cvas I am running - I assume the mip ones are the same bell size
HH TQ10
I have a set of RC10T MIP CVD's NIP can i just get the 3/16 MIP T4 axles to use instead of the 1/4 10T ones?
- PBR Allstar
No, the offset on the T4 parts are different. you need the axles from the B2/3, T2/3 or a custom works oval car.Caine wrote:I have a set of RC10T MIP CVD's NIP can i just get the 3/16 MIP T4 axles to use instead of the 1/4 10T ones?
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXAW08&P=SM
the t3 stub axles fit in the rc10t hubs. this way you can run rc10t dogbones with t4 wheels.....
I built the CVDs and was ready to install them (using AE CVD set, RC10T rear hubs, 3/16 bearings, spacers) but they don't fit if I use all the shims the instructions say to.
The instructions call for two shims inside the hub and three on the outside before the pin. Do I need T2 or T3 rear hubs?
I'm sure I could get away with one inside and one out, but I just want to see what you guys think. Any thoughts?
SC10 -- FT B4.1
- Has thanked: 10 times
- Been thanked: 447 times
the shims are there to take up slack, and possibly fine tune the placement of the bone in the drive cup.
use as many as it takes to fit it properly, and stick the leftovers in your stash of spare parts. no big deal.
- 945 Views
Last post by RC104ever
- 23 Replies
- 2234 Views
Last post by m_vice
- 805 Views
Last post by MelvinsArmy
- 20 Replies
- 3800 Views
Last post by slow_jun
- 1313 Views
Last post by 2500M_Sub
- 1677 Views
Last post by RadioFlyer
- 1210 Views
Last post by fredswain
- 192 Views
Last post by BeastyShout
