RPM rear bulkhead. What tower???
Twiceblown351
Post by Twiceblown351 »
What shock tower can I use the RPM rear bulkhead? It looks like a 10GT will work but I think its going to be to tall for a buggy and a body will not fit. Its for a RPM ulta Buggy.
Thanks
Twiceblown= 93 F150 Lightning
393 and two turbos @ #10Psi
= 10.90@126 in street trim
Asso_man!
Has thanked: 40 times
Been thanked: 82 times
Re: RPM rear bulkhead. What tower???
Post by Asso_man! »
The RPM "Team Car" rear bulkhead has the same hole positions, the "ultra molded" one has 2 pairs of aligned holes to fit the RPM "ultra molded" rear shock tower. As the latest is quite hard to find, your best bet would be to drill 2 extra holes in a stock/aftermarket rear shock strut
Come and visit the stable
templeofspeed
Been thanked: 33 times
Post by templeofspeed »
If you're doing a truck you use a normal 10T rear tower, use the bulkhead as a template for the upper holes, marking them with a small nail.
