rpm team car bulkhead and worlds tower???
- lowrydesign
- Has thanked: 11 times
- Been thanked: 22 times
has any one tried to use a rpm team car rear bulkhead with a worlds rear tower??
do the holes that have to be drilled into the shock tower actually line up ???
- Charlie don't surf
- Has thanked: 355 times
- Been thanked: 470 times
Re: rpm team car bulkhead and worlds tower???
if you can do without the top mounting screws they mount up fine, if you did try to drill the bulkhead, you wouldn't have enough "meat" because of the hole in the bulkheadlowrydesign wrote:has any one tried to use a rpm team car rear bulkhead with a worlds rear tower??
- lowrydesign
what about the upper hole your supposed to drill into the tower.. where does it land??Charlie don't surf wrote: if you can do without the top mounting screws they mount up fine, if you did try to drill the bulkhead, you wouldn't have enough "meat" because of the hole in the bulkhead
- lowrydesign
crappy...... that combo looks so good tooCharlie don't surf wrote:too close to the relief hole to drill in my opinion
Actually, I just re-looked at it, looks like there is enough--thank god I finally have my Nikon back!!
- lowrydesign
Charlie don't surf wrote:Actually, I just re-looked at it, looks like there is enough--thank god I finally have my Nikon back!!
would you actually drill the bulkhead.. i know i would.. only cause i have a used one that is dyed black.....
- Asso_man!
- Has thanked: 40 times
- Been thanked: 82 times
maybe you should relocate one of the rear ball studs or is this a special "racer" trick?Charlie don't surf wrote:Actually, I just re-looked at it, looks like there is enough--thank god I finally have my Nikon back!!
Come and visit the stable
I'm still torn between using RCPS or Tecnacraft's, the car is currently mocked up with tecna's on the right side, RCPS on the left--and the RCPS are a little longer than the tecna's--hence the difference in the ball stud location. Nice catch though
sounds like a perfect opportunity to fab your own rear tower with some extra meat for the 2 mounting holes........using the worlds tower as a template.
nice, thats what ive been looking for?rear Bulkhead and Tower, where did you get it? can you send the links?
thanks in advance.
thanks in advance.
― Confucius
― Confucius
- blown5.0
Slow_jun - these parts are no longer available, your only hope is to keep an eye open for some to pop up in the classifieds or Ebay.
- 1144 Views
- 469 Views
Last post by templeofspeed
- 645 Views
- 2756 Views
Last post by sandkil
- 35 Replies
- 5324 Views
Last post by ra272
- 1026 Views
Last post by Caine
- 613 Views
Last post by jcwrks
- 1379 Views
Last post by JersJeeps
Users browsing this forum: Google Adsense [Bot] and 5 guests
