brushless power!!!
lowrydesign
Has thanked: 11 times
Been thanked: 22 times
brushless power!!!
Post by lowrydesign »
while doing some r&d in the beat lab today i notice that while running my mamba max 6900kv in my rc10 buggy with rpm truck trans the diff got to feeling a bit funny so i took it apart and examined it, i found that the diff balls got so hot they actually melted into the diff gear!!! see pic
greazy
Re: brushless power!!!
Post by greazy »
I used to have Losi do that all the time no matter what I did to them :x
Bugle
Post by Bugle »
lol I haven't had that problem with mine, must be running the diff a bit loose.
Problem I have with my RPM trans is it munches idler gears all the time..
lowrydesign
Bugle wrote:lol I haven't had that problem with mine, must be running the diff a bit loose.
oh it does that too, and the diff was set on the tighter side this time.......
longboardnj
Post by longboardnj »
does it still do this if you tighten it all the way??
lowrydesign
that damages the balls???
WillyThickfoot
Been thanked: 9 times
Post by WillyThickfoot »
And we dont want that!! :shock:
wts873
Post by wts873 »
how's your slipper set?
longboardnj
i run my diffs tight and have not had a prob..sure its not as smooth but it still works..the way a.e. tells you to set it is smooth. but they only had brushed motors running 1700 nicads back then..all the power of your brushless you may have to make it tighter.. i dont run brushless or lipo but i have run 14.4 volts in rcs before and all that power can turn a reliable rc into an rc that cant stay together...
lowrydesign
wts873 wrote:how's your slipper set?
so it doesn't slip... aka all the way tight...lol
i am running lipo 2s 30c 5200mah packs
Has thanked: 3699 times
Been thanked: 1980 times
You may want to try setting your punch control at 100%. It helps for smooth take-offs and will take some of the strain off the drivetrain. Hah! :lol: I'm a friggin' poet!
