6gear trans with losi diff??any good? let me know
- longboardnj
i saw this set up. it has a bearing on the diff mount/tube. the guy said,"The slipper clutch has a bearing in the diff tube which I believe is a Losi diff tube". is this any good (aftermarket,or losi),has this been done before with no mods to trans or is this junk?
- a01butal
- Has thanked: 34 times
- Been thanked: 40 times
Re: 6gear trans with losi diff??any good? let me know
Losi made a diff tube for the 6 gear I believe but it is just a replacement for the original not a whole diff gear. I see themn around ever once in a while.
This is all very interesting!
- longboardnj
so only the 1 part is different and if i got this trans and wanted to change back to stock associated part i could ? or was it an old school grind/cut to fit part and you need to replace more parts to return to stock?Losi made a diff tube for the 6 gear I believe but it is just a replacement for the original not a whole diff gear. I see themn around ever once in a while
- Has thanked: 36 times
- Been thanked: 1318 times
ya.wts873 wrote:Is the shaft just in backwards?
i kinda interested to see if that's a tq10 motor plate, or just a stealth plate on a 6 gear.
- longboardnj
tq10 motor plate,stealth plate or a stock painted black whats worth most??i kinda interested to see if that's a tq10 motor plate, or just a stealth plate on a 6 gear.
it's a stealth plate.......... i just saw the auction.
a tq10 plate is a lot more rare.
- longboardnj
- a01butal
If someone doesn't answer this before tomorrow I will have a definitive answer for you but I still think it was just a direct replacement part. Of course you can grind/cut anything if you want and some might reccommend that anyway.longboardnj wrote:so only the 1 part is different and if i got this trans and wanted to change back to stock associated part i could ? or was it an old school grind/cut to fit part and you need to replace more parts to return to stock?Losi made a diff tube for the 6 gear I believe but it is just a replacement for the original not a whole diff gear. I see themn around ever once in a while
- a01butal
See I knew you'd save me the time responding tomorrow.scr8p wrote:ya, it's a direct replacement piece.
- templeofspeed
- Has thanked: 3 times
- Been thanked: 33 times
You may find that trans is full of hop-up goodies... note the large out drive bearings.
Nothing wrong with a modded six-gear.
- longboardnj
well i went to b.i.n and then someone bid so i bid then was out bid with 1 min left...oh well... wanted that stealth motor plate and losi diff part..anyone know where i could get this diff part??part# or any info would be great...
- a01butal
I may be able to come up with something but it may take a while. There around.
- 1902 Views
Last post by alien3t
- 1361 Views
Last post by longboardnj
- 674 Views
Last post by Asso_man!
- 823 Views
- 2297 Views
Last post by flustorm99
- 1143 Views
Last post by RC10th
- 1370 Views
Last post by carloco8
- 56 Replies
- 12075 Views
Last post by XLR8
