B4/T4 diff in a T2/GT trans case
- Has thanked: 36 times
- Been thanked: 1318 times
Re: B4/T4 diff in a T2/GT trans case
Ehh..... nevermind. Doing a little research I found that while the b4/t4 still used 3/8 x 5/8 outdrive bearings, the 4.1 and 4.2 switched to 10 x 16 mm outdrive bearings. What I was looking to use is based on the 4.1 and later diff.
when i realized AE was going full metric, i bought as many t4 diff kits i could stand to pay for...i wish i thought about the gt cvd's too...
now, to try and retrofit a gear diff in to a sae case.....
- RC10th
- Has thanked: 52 times
- Been thanked: 1548 times
I would have thought the 4.1 and 4.2 would have had the same diff as the previous T4 models. I don't have my manuals handy at the moment but have you checked part numbers on the gear case etc?
The B4/T4 used a T2/GT diff and 9574 trans case
The .1 and .2 used the 9852 outdrives and 9826 gear diff trans case.
- RC10th
Hmm, I had to get out of bed to look
What a stupid idea, every bearing in the kit is imperial while the diff bearings are metric.
Just to confuse things the RTR T4.1 uses the standard GT diff while the FT T4.1 an T4.2 use the 10x16 bearing diff.
- 3323 Views
Last post by jb7778
- 789 Views
Last post by ACTIVETHUNDERRC
- 801 Views
Last post by LowClassCC
- 1129 Views
Last post by Chewbacca
- 19 Replies
- 8878 Views
Last post by klavy69
- 2798 Views
Last post by Groomi
- 1362 Views
Last post by carloco8
- 56 Replies
- 12014 Views
Last post by XLR8
