rc10 rolls in the turns
vintagerc10
Post by vintagerc10 »
Hello all, just found this forum and i'm very impressed. I've recently pulled my gold tub out of storage and re-built it for my son. my problem is i cant seem to keep it from rolling in the turns (on the street). besides softening the rear suspension, what options do i have? Are there any wide arms from maybe a different model i could install?
any thoughts would be greatly appreciated.
Has thanked: 3699 times
Been thanked: 1980 times
Re: rc10 rolls in the turns
vintagerc10 wrote:Hello all, just found this forum and i'm very impressed. I've recently pulled my gold tub out of storage and re-built it for my son. my problem is i cant seem to keep it from rolling in the turns (on the street). besides softening the rear suspension, what options do i have? Are there any wide arms from maybe a different model i could install?
What kind of radio do you have? If it has adjustable servo end point adjustments you can just turn the steering back a bit. Stiffening the rear suspension may help it spin-out instead of roll.
vintagerc10
im running my old futaba magnum jr.
i'll try to stiffent the rear. i've been playing with different oil, springs and shocks and it seemed to not roll with soft springs.
RedScampi
Post by RedScampi »
Let your son drive. :mrgreen: :mrgreen:
Gary
vintagerc10 wrote:im running my old futaba magnum jr.
There is a large wheel on the handle of the radio. Steer the tires all the way left or right and turn that wheel so the steering doesn't extend as far. If it's rolling you should still have plenty of steering. That way you don't have to throw off other applications with a stiffer suspension.
vintagerc10
RedScampi - NO WAY. He gets to drive the traxxas stampede and dad gets the rc10.
Theytook..... - thank you for the suggestion, i'll try that next.
RedScampi
Post by RedScampi »
Good call! I was just kidding of course. :wink:
Gary
Asso_man!
Has thanked: 40 times
Been thanked: 82 times
Post by Asso_man! »
Welcome aboard! A pic from your car would help to...help your son :D
Come and visit the stable
vintagerc10
Asso_man - thanks for the greeting. I'll snap some pics this weekend.
for future reference, can i get wider rear arms for this car?
also, are the ball bearing steering kits worth it?
thanks again guys!
Twiceblown351
Post by Twiceblown351 »
Well you can buy wide front a-arms from RPM right from there website. If you going to run it on the street a lot . A wide front tire and a really big rear sway bar and a regular front sway bar will stop that. and lower it some too.
I have a really fast RC10 street car set up like this and it won't roll. It will under steer but it won't roll
Twiceblown= 93 F150 Lightning
393 and two turbos @ #10Psi
= 10.90@126 in street trim
GJW
Post by GJW »
just try lowering the whole buggy, you can move the shocks where they mount on the shock towers so the end result is the suspension arms sitting more horizontal, also put the shock clamps at the top of the shock..pics would help us..good luck 8)
Users browsing this forum: No User AvatarBing [Bot] and 5 guests
