Brushless Turns Equivalents to Brushed Turns
- vintage AE
- Has thanked: 29 times
- Been thanked: 36 times
My brain is turning but I'm not getting nowhere quick
I'm sure there is a chart somewhere out there to tell us what the equivalent brushless motor turns are to brushed motor turns. Maybe this can be a quick and painless fix for me and possibly others. Any links people are willing to share would be greatly appreciated.
cheers,
Anthony
cheers,
Anthony
Re: Brushless Turns Equivalents to Brushed Turns
I have a Speed-T that has a 4800Kv motor. I asked Horizon hobbies, and they said this was an equivalent to a 9.5T motor, if compared to a sensored one.
The Higher the Kv, the lower T motor it would be compared to....
This chart might help as well. If you look at the Kv4 (RPM/volt) matched up to the turns of the motor, it can get you close.
http://www.teamnovak.com/products/brushless/motor_spec_chart.htm
- Been thanked: 12 times
from what I have seen, 17.5 brushless is roughly equivalent to 27t brushed stock and are raced together, and 13.5 brushless matches up against 19T brushed motors. anything lower than that I don't know.
- vintage AE
that's a good chart for comparing Kv to brushless turnsy2kgtp wrote:This chart might help as well. If you look at the Kv4 (RPM/volt) matched up to the turns of the motor, it can get you close.
personally, I am looking for the brushless equivalent to brushed 19t down to 12t
but, i think any other info will be beneficial to who ever visits the thread
Woops...I guess I read that wrong too.....I was thinking sensored to sensorless as it was on my mindvintage AE wrote:that's a good chart for comparing Kv to brushless turnsy2kgtp wrote:This chart might help as well. If you look at the Kv4 (RPM/volt) matched up to the turns of the motor, it can get you close.
http://www.teamnovak.com/products/brushless/motor_spec_chart.htm![]()
personally, I am looking for the brushless equivalent to brushed 19t down to 12t![]()
From what our gang has seen at several off road tracks a 19T spec motor seems to fall between a 10.5 and 13.5. Guys switch to 19T spec brushed for the tracks that combine 13.5/19, 10.5 for 10.5/19 tracks.
My rough guesses just based on observation and talking to various skill level drivers:
17T ~ 10.5
14T ~ 8.5
12T ~ 7.5
10T ~ 6.5
7T ~ 4.5
For entertainment purposes only, no wagering please.
Cheers
17T ~ 10.5
14T ~ 8.5
12T ~ 7.5
10T ~ 6.5
7T ~ 4.5
Cheers
- JK Racing
- Has thanked: 139 times
- Been thanked: 246 times
it is REALLY hard to put a brushed equivalent onto these motors due to the torque involved. a 17.5 is equal to a 27T is a joke (and I say that watching the brushless stock motors kill the brushed ones)...geared the same, the 27T will kill it in top end. the brushed motors have more RPM than the "equal" brushless motor, but with the torque difference, brushless takes the cake.
To further this arguement....
17.5 Novak is rated 2200 Kv @ 7.2 volts = 15480 RPM.
a decent 27T motor is 25000 + RPM, and I have seen them in the 27~28 range (team drivers at regional/national events)
No comparision, but a 17.5 geared right will kill a 27T.
So better question would be, what are you trying to accomplish with a brushless motor and shoot for that, not try to match a brushed motor you currently run.
Oh...a 10.5 was supposed to be close to a 12 turn brushed at one time...
- 59burst
what I heard was brushless x 1.78 = brushed. someone says 1.8 for 10.5T (or 11.5) and less, 1.7 for over 10.5T
I had LRP X11 4.5T/5.5T/6.5T and run Orion vortex 6.5T/7.5T these days. this 1.7~1.8 muliplication seems to work to me
BLS 4.5T = Brushed 8T (4.5x1.8=8.1)
BLS 5.5T = Brushed 10T (5.5x1.8=9.9)
BLS 6.5T = Brushed 12T (6.5x1.8=11.7)
BLS 10.5T = Brushed 19T (10.5x1.8=18.9)
BLS 13.5T = Brushed 23T (13.5x1.7=22.95)
it's NOT a correct table. but not quite worng I think.
in my case, Reedy Ti 12T = LRP X11 6.5T and, Orion 6.5T showed better performance than these two.
- 59burst
I just found this link at rctech.net
http://www.teamnovak.com/products/brushless/ss13.5/index.html
http://www.modelsport.co.uk/?CallFunction=ShowSpecification&ItemID=27905
novak says 13.5T = brushed 27T
nosram(LRP) says 13.5T = brushed 23T
break in? brushes?
break in? brushes?
- 756 Views
Last post by seismic
- 1591 Views
- 1581 Views
Last post by MAC10
- 1489 Views
Last post by GJW
- 1429 Views
Last post by Qballll
- 1590 Views
Last post by jeekelemental
- 1062 Views
Last post by muck
- 512 Views
Last post by azone
