on road conversion arrived today new picks
- Has thanked: 36 times
- Been thanked: 1318 times
Re: on road conversion
i highly doubt your gonna find a body that those back tires are gonna tuck up under. it has to be like 11" wide...... atleast. plus, you'll never get the front end that wide. years ago, twinn-k (and probably others) made narrow rear pancar rims. if you could find a pair of them, mount them backwards. then the lip of the rim won't hit the hub carrier, and the track width should be quite narrower.
either that, or get some custom works rims with mounted foam tires and true them down to pancar diameter. that should work pretty good, too. maybe.
- JK Racing
- Has thanked: 139 times
- Been thanked: 246 times
I used to run pan car rears on my JRX2....I measured the depth to the rear carriers, and took an xacto to the rims while spinning on the car (okay...kill me, but I was a kid, I didnt know better).
After they were so crudely cut, I flipped them around and they tucked under my nascar body just fine!!
- highwayracer
- Been thanked: 6 times
You actually have a few options. Losi made direct bolt on wheels for the jrx2 that was designed for foam tires. They look like the logo wheels without the ribs.
Another option would be to take any rear losi tire, cut the ribs and mount foams. HPI did this and so did several other companies.
Regards,
highwayracer
Regards,
highwayracer
If you are interested, I know of a couple guys who mount foams on offroad rims. For "stadium" racing, carpet track with jumps.
- Has thanked: 43 times
- Been thanked: 56 times
http://www.tm-rc-racingcomponents.com/WebSite/2%20inchFrame1Source1.htm
Buggy sized rims mounted with foam
- FasterLouder
- Has thanked: 13 times
- Been thanked: 59 times
Hey,I have a huge lot of Losi 'Logo' rims for mounting foam tires,in various colours,on the way.highwayracer wrote:You actually have a few options. Losi made direct bolt on wheels for the jrx2 that was designed for foam tires. They look like the logo wheels without the ribs.
Regards,
highwayracer
P/M me and I'll hook you up with a set when they arrive.
All The Way Alive
- bearrickster
Re: on road conversion arrived today new picks
I would get a parma 57 chevy I use to run my Jrx pro loward with a 50 merc painted up like the one from the movie Cobra with sly stallone I would build another one if I could find another body I loved it.
- 1851 Views
Last post by purpletimbo
- 348 Replies
- 34126 Views
Last post by FoxShot
- 3346 Views
Last post by lmw94002
- 55 Replies
- 5669 Views
Last post by tyhodge07
- 952 Views
Last post by THEYTOOKMYTHUMB
- 1037 Views
Last post by therigliveson
- 23 Replies
- 3402 Views
Last post by SMOKE-DOG
- 1608 Views
Last post by LTO_Dave
Users browsing this forum: Bing [Bot] and 2 guests
